[ ERROR ] Demo supports topologies only with 1 input
Hung__Edwin
When I run instance-segmentation-security-0049.xml  model
environment : ubuntu16.04
has some error below
$ ./segmentation_demo -i /home/asrock/inference_engine_samples_build/intel64/road_1.jpg -m /home/asrock/inference_engine_samples_build/intel64/instance-segmentation-security-0049/instance-segmentation-security-0049.xml -d CPU
[ INFO ] InferenceEngine:
    API version ............ 1.6
    Build .................. custom_releases/2019/R1.1_28dfbfdd28954c4dfd2f94403dd8dfc1f411038b
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     /home/asrock/inference_engine_samples_build/intel64/road_1.jpg
[ INFO ] Loading plugin
    Build .................. 23780
    Description ....... MKLDNNPlugin
[ INFO ] Loading network files
[ INFO ] Preparing input blobs
Michael_C_Intel1
Hello EdwinH,
It looks like this issue is related to the OpenVINO toolkit... I'll be moving this thread to the Computer Vision forums so that community has visibility.
-MichaelC
Shubha_R_Intel
Dear Hung, Edwin,
Can you kindly try the Python Instance Segmentation Demo instead ? That's a different one than C++ segmentation_demo which are trying to run. Please let me know how it works for you.
The way I figured it out was by looking at the OpenVino Samples Matrix - at the bottom of the page you'll see a matrix which matches up the sample you should run per Intel model.
Shubha
ahasan_
I am kind of facing the same problem but I am using instance_segmentation_demo.py and the error is  'Demo supports only topologies with the following input keys: {}'.format(', '.join(required_input_keys))' .
AssertionError: Demo supports only topologies with the following input keys: im_info, im_data
command: python instance_segmentation_demo/instance_segmentation_demo.py -m D:/Mask_Robot_neural_stick2/frozen_inference_graph.xml --label D:/Mask_Robot_neural_stick2/frozen_inference_graph.labels --images 1.png
environment : Windows 10
I am using the latest version of the openvino. and my files are as follows:
Max_L_Intel
Hello @ahasan_
Old threads are no longer monitored by OpenVINO staff, so please create a new one.
