Hi
I am trying to make the examples in ubuntu 16.04:
git clone -b ncsdk2 http://github.com/Movidius/ncsdk && cd ncsdk && make installworks seamleslyAt the time that I executed
sudo make examplesmy opencv version was 3.3.0.No problem with NCS connection because hello_ncs_cpp gives following:
Hello NCS! Device opened normally.
Goodbye NCS! Device Closed normally.
NCS device working.However when I execute
sudo make examplesI get the following error.Generating Profile Report 'output_report.html'…
making caffemodel
caffemodel file already existsmaking check
mvNCCheck -w bvlc_alexnet.caffemodel -i ../../data/images/cat.jpg -s 12 -id 281 deploy.prototxt -M 120 -S 255 -metric top1
/usr/lib/python3/dist-packages/scipy/stats/morestats.py:16: DeprecationWarning: Importing from numpy.testing.decorators is deprecated, import from numpy.testing instead.
from numpy.testing.decorators import setastest
mvNCCheck v02.00, Copyright @ Intel Corporation 2017WARNING: Logging before InitGoogleLogging() is written to STDERR
F1111 21:02:15.150092 18164 upgrade_proto.cpp:95] Check failed: ReadProtoFromBinaryFile(param_file, param) Failed to parse NetParameter file: bvlc_alexnet.caffemodel
*** Check failure stack trace: ***
Makefile:84: recipe for target 'check' failed
make[3]: [check] Aborted (core dumped) (ignored)making compile
mvNCCompile -w bvlc_alexnet.caffemodel -s 12 deploy.prototxt
mvNCCompile v02.00, Copyright @ Intel Corporation 2017WARNING: Logging before InitGoogleLogging() is written to STDERR
F1111 21:02:18.345795 18185 upgrade_proto.cpp:95] Check failed: ReadProtoFromBinaryFile(param_file, param) Failed to parse NetParameter file: bvlc_alexnet.caffemodel
Makefile:79: recipe for target 'compile' failed
make[3]: *** [compile] Aborted (core dumped)
make[3]: Leaving directory '/home/akde20/ncsdk/examples/caffe/AlexNet'
Makefile:12: recipe for target 'AlexNet' failed
make[2]: *** [AlexNet] Error 2
make[2]: Leaving directory '/home/akde20/ncsdk/examples/caffe'
Makefile:12: recipe for target 'caffe/.' failed
make[1]: *** [caffe/.] Error 2
make[1]: Leaving directory '/home/akde20/ncsdk/examples'
Makefile:57: recipe for target 'examples' failed
make: *** [examples] Error 2
@akde Sorry for the late reply. I was on vacation and I just got back. Have you tried using make examples without sudo? Also make sure to open a new terminal window after installation of the NCSDK to run/build the NCSDK examples. This will make sure your new PYTHONPATH environment variable is enabled.
@Tome_at_Intel I have encountered the same error and have tried using make examples without sudo and opened up a new terminal window after the installation to run/build the NCSDK examples. Any solutions or other suggestions?
I have the same trouble running on a raspi3
-jc
Hi @johncohn & @JMB
Try uninstalling by running make uninstall, then make clean, then reinstall the ncsdk2 by running make install.
Be sure to set new pythonpath environment variables, then close the terminal and re open a new one to run
make examples.Please let me know if this information is helpful.
Sahira
