I am using Model Optimizer to convert two different models built on different versions of Caffe with the same neural network, both files convert successfully and generate xml and bin files. When I use the python or C++ classification samples tools to perform inference one returns the following error "[ ERROR ] Sample supports topologies with 1 output only" , the other model works and returns a valid result. Does any one know why I am getting the above error and how I fix it?
Managed to solve this by using the hello_classification sample instead.
