6584 Discussions
[ ERROR ] VX API call failed with VX_FAILURE
Deepak_C_R
I have modified cnn_custom_kernel sample code by adding one more custom layer. But I am getting following errors while running the binary.
deepak@camry:~/Projects//openvx_samples/build/install/bin/cnn_custom_kernel$ ./cnn_custom_kernel
    expression: vxLoadKernels(context, "cnn_custom_kernels")
    file:       /home/deepak/Projects/openvx_samples/samples/cnn_custom_kernel/main.cpp
    line:       133
May I know the reason for this error.
Thank You.
Stav_S_Intel
Without knowing what you're trying to run it is very hard to understand, you can look at the log or tracer- there are instructions to activate them on the Runtime user document...
Or you can send me the files and i will try to reproduce.
Stav
