I'm trying to use the model optimizer to convert custom Unet like model. I'm using this command
python mo_tf.py --input_model ~/model/frozen_model.pb
But I receive an error:
[ ERROR ] Graph contains 0 node after executing <class 'extensions.front.output_cut.OutputCut'>. It considered as error because resulting IR will be empty which is not usual Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.front.output_cut.OutputCut'>): Graph contains 0 node after executing <class 'extensions.front.output_cut.OutputCut'>. It considered as error because resulting IR will be empty which is not usual
You can find my frozen model in the attachments.
Thank you in advance.
Hi Vlad,
Which base model did you use to custom train your model? The OpenVINO toolkit supports Unet from this particular repository: https://github.com/kkweon/UNet-in-Tensorflow
Also, how did you freeze the model?
Jesus
