6594 Discussions
ERROR when converting tensorflow model to IR
Li__yajun
I am trying to convert the tensorflow ICNet model https://github.com/hellochick/ICNet-tensorflow using the following command,
python mo_tf.py --input_model model.pb --data_type FP16
It generates the following error
[ ERROR ]  Graph contains 0 node after executing <class 'extensions.front.output_cut.OutputCut'>. It considered as error because resulting IR will be empty which is not usual
Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.front.output_cut.OutputCut'>): Graph contains 0 node after executing <class 'extensions.front.output_cut.OutputCut'>. It considered as error because resulting IR will be empty which is not usual
Before converting ,I have followed the guides https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html#freeze-the-tensorflow-model  to freezing the data and saved as model.pb.
Please advise .Thanks.
