6582 Discussions
Enter OpenVINO DL workbench issue : Signature verification failed
BBi
issue description:
after installing docker ok,then install DL workben, run "sudo docker run -p 127.0.0.1:5665:5665 --name workbench --privileged -v /dev/bus/usb:/dev/bus/usb -v /dev/dri:/dev/dri -e PORT=5665 -it openvino/workbench:latest" and displayed the login token。
then login "http://127.0.0.1:5665" in the browser and input the token in the input-box, click on "start",and transfer to "Active Configurations" page, during configuration it returned to the “Enter login token” page,and always like this. why? and could you tell me how to solve this issue?
IntelSupport
Community Manager
Hi Bi,
Thank you for reaching out. If possible, could you log in via the available DL Workbench link on the terminal and execute the configuration process?
If it doesn't work, please log in again, click Create on the Activate Configurations page,  go to Environment on the Create Configuration page, click Platform, choose Intel Core (CPU core), and execute the configuration process.
If it doesn't work, please share the additional information regarding:
• Any docker logs obtained while doing the whole process.
• Docker version and Operating System information.
Adli
IntelSupport
Community Manager
Hi Bi,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Adli
