6598 Discussions
Model Optimizer config step failed in TensorFlow 1.x / 2.x while install OpenVINO 2021.1
Noway
Hi~Teams
I follow the below website to install OpenVINO 2021.1
https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_linux.html#install-openvino
and in "Configure the Model Optimizer" step, I encountered an error shown as below, when I issued the command  " sudo ./install_prerequisites.sh"
after doing some research, I found a solution on github as below links
https://github.com/openvinotoolkit/openvino/issues/2843
but it didn't work after I tried this solution, the problem still here, detailed steps as below
uninstall numpy with version 1.19.4
uninstall successfully and install numpy with 1.18.5 version
issued "sudo ./insatll_prerequisites.sh" command
My question is how to solve this problem or it is a minor issue due to the other training model install very well when I configure those models separately.
By the way, I using Ubuntu 18.04.4 LTS version via VMware Workstation 15 in Windows 10.
BR
Noway
Rizal_Intel
Hi Noway,
I replicated and encountered the same issue. However, after upgrading pip I was able to install the prerequisites. Try to upgrade pip to latest version with
>python3 -m pip install --upgrade pip setuptools
Rizal
Rizal_Intel
Hi Noway,
Rizal
Noway
HI~Rizal
This problem has been resolved by your advice.
Many thanks
BR
Noway
Rizal_Intel
Hi Noway,
Glad to help you.
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Rizal
