6597 Discussions
[Error 25] Myriad Error: "Cannot Allocate space for convolution.".
Hi, has anyone encountered the following error: [Error 25] Myriad Error: "Cannot Allocate space for convolution.".
When I execute: python3 ./mvNCCheck.pyc ~/Documents/dex/age.prototxt -w ~/Documents/dex/dex_imdb.wiki.caffemodel
This error is followed after a warning:
[libprotobuf WARNING google/protobuf/io/coded_stream.cc:537] Reading dangerously large protocol message. If the message turns out to be larger than 2147483647 bytes, parsing will be halted for security reasons. To increase the limit (or to disable these warnings), see CodedInputStream::SetTotalBytesLimit() in google/protobuf/io/coded_stream.h.
[libprotobuf WARNING google/protobuf/io/coded_stream.cc:78] The total number of bytes read was 538700275
USB: Transferring Data…
I'm using a pre-trained CNN.
this is the prototxt structure
input: "data"
input_shape {
dim: 1
dim: 3
dim: 224
dim: 224
layer {
bottom: "data"
top: "conv1_1"
type: "Convolution"
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
layer {
bottom: "conv1_1"
top: "conv1_1"
type: "ReLU"
layer {
bottom: "conv1_1"
top: "conv1_2"
type: "Convolution"
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
layer {
bottom: "conv1_2"
top: "conv1_2"
type: "ReLU"
layer {
bottom: "conv1_2"
top: "pool1"
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
bottom: "pool1"
top: "conv2_1"
type: "Convolution"
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
layer {
bottom: "conv2_1"
top: "conv2_1"
type: "ReLU"
layer {
bottom: "conv2_1"
top: "conv2_2"
type: "Convolution"
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
layer {
bottom: "conv2_2"
top: "conv2_2"
type: "ReLU"
layer {
bottom: "conv2_2"
top: "pool2"
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
bottom: "pool2"
top: "conv3_1"
type: "Convolution"
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
layer {
bottom: "conv3_1"
top: "conv3_1"
type: "ReLU"
layer {
bottom: "conv3_1"
top: "conv3_2"
type: "Convolution"
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
layer {
bottom: "conv3_2"
top: "conv3_2"
type: "ReLU"
layer {
bottom: "conv3_2"
top: "conv3_3"
type: "Convolution"
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
layer {
bottom: "conv3_3"
top: "conv3_3"
type: "ReLU"
layer {
bottom: "conv3_3"
top: "pool3"
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
bottom: "pool3"
top: "conv4_1"
type: "Convolution"
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
layer {
bottom: "conv4_1"
top: "conv4_1"
type: "ReLU"
layer {
bottom: "conv4_1"
top: "conv4_2"
type: "Convolution"
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
layer {
bottom: "conv4_2"
top: "conv4_2"
type: "ReLU"
layer {
bottom: "conv4_2"
top: "conv4_3"
type: "Convolution"
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
layer {
bottom: "conv4_3"
top: "conv4_3"
type: "ReLU"
layer {
bottom: "conv4_3"
top: "pool4"
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
bottom: "pool4"
top: "conv5_1"
type: "Convolution"
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
layer {
bottom: "conv5_1"
top: "conv5_1"
type: "ReLU"
layer {
bottom: "conv5_1"
top: "conv5_2"
type: "Convolution"
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
layer {
bottom: "conv5_2"
top: "conv5_2"
type: "ReLU"
layer {
bottom: "conv5_2"
top: "conv5_3"
type: "Convolution"
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
layer {
bottom: "conv5_3"
top: "conv5_3"
type: "ReLU"
layer {
bottom: "conv5_3"
top: "pool5"
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
bottom: "pool5"
top: "fc6"
type: "InnerProduct"
inner_product_param {
num_output: 4096
layer {
bottom: "fc6"
top: "fc6"
type: "ReLU"
layer {
bottom: "fc6"
top: "fc6"
type: "Dropout"
dropout_param {
dropout_ratio: 0.5
layer {
bottom: "fc6"
top: "fc7"
num_output: 4096
layer {
bottom: "fc7"
top: "fc7"
type: "ReLU"
layer {
bottom: "fc7"
top: "fc7"
type: "Dropout"
dropout_param {
dropout_ratio: 0.5
layer {
bottom: "fc7"
top: "fc8-101"
num_output: 101
layer {
bottom: "fc8-101"
top: "prob"
type: "Softmax"
Thanks million!
@4nd4 Thank you for bringing this to our attention. This is a known bug. We are looking into it and will notify you when there is a fix.
are there any updates for the bug fix? @Tome_at_Intel
Are there any bug fixes? I also have this problem.
@Tome_at_Intel Is there any update on this? What kind of structure leads to this error?
@gauravmoon @yairh @csarron @4nd4 Thanks for the responses. Currently, we are testing a release candidate and while we can't give a ETA for the fix, I will be updating this post ASAP when the fix is released. Thank you for your patience!
@4nd4 Please try the new NCSDK version 1.10.01 with support for VGG16 and let us know your results
Hi @Tome_at_Intel I downloaded the extended examples from https://github.com/movidius/ncappzoo which do not include VGG16.
The version on Github https://github.com/movidius/ncsdk/tree/master/examples also doesn't have VGG16. Where can I get VGG16 example from?
@preetibindu Unfortunately there isn't a VGG sample code available at the moment.
