6616 Discussions
[Error 44] Toolkit Error: Unsupported: Multiple graph inputs or Malformed graph connections
I got this error while trying to compile my caffe model to movidius. Any help would be great.
mvNCCompile -w net.caffemodel -s 12 net.prototxt
/usr/local/bin/ncsdk/Controllers/Parsers/TensorFlowParser/Convolution.py:46: SyntaxWarning: assertion is always true, perhaps remove parentheses?
assert(False, "Layer type not supported by Convolution: " + obj.type)
/usr/local/bin/ncsdk/Controllers/Parsers/Phases.py:322: SyntaxWarning: assertion is always true, perhaps remove parentheses?
assert(len(pred) == 1, "Slice not supported to have >1 predecessors")
mvNCCompile v02.00, Copyright @ Intel Corporation 2017
[Error 44] Toolkit Error: Unsupported: Multiple graph inputs or Malformed graph connections.
Makefile:87: recipe for target 'compile' failed
make: *** [compile] Error 255
Thank you.
These two lines show what the errors are.
The tfparser will check those assertion when compiling. So I think your network structure contains some errors or it is not supported by now.
PJIA01
It looks both NCSDK1 and NCSDK2 are now replaced by OpenVINO?
Cheers
Pei
