Hi Team,
i try to test this model " person-vehicle-bike-detection-crossroad-1016 "
when i run this command " /object_detection_demo -d MYRIAD -m /home/pi/open_model_zoo/tools/downloader/intel/person-vehicle-bike-detection-crossroad-1016/FP16/person-vehicle-bike-detection-crossroad-1016.xml -at ssd -i 0 " its working but just for a while and for a few of minutes i got error
Please let me know the workaround to avoid the error.
rnd
連結已複製
Hi rnd,
The error you got is because of Intel® Neural Compute Stick 2 (NCS2) connection issue. This could happen due to NCS2 disconnecting during inference, low USB power, poor contact, etc.
Here are some steps you could try to solve this issue:
- Ensure that the NCS2 is listed among the USB devices using lsusb command.
- Please ensure that your NCS2 is connected securely to the USB port.
- Connect NCS2 directly to a USB 3.0 port instead of a USB hub.
- Connect NCS2 to a powered USB hub.
- Disconnect other unnecessary devices from the USB ports.
For your information, I ran the Object Detection C++ Demo with Raspberry Pi 4 Model B and NCS2, and did not encounter any errors. However, I got the same error as yours when the NCS2 was disconnected while the demo was running as shown here.
Megat
Hi @Megat_Intel ,
i think it's because i used extension cable for NCS2
any similars models that already stable & already have a report like counting each object ( vehicle, person ) and di object capture by cctv ( rtsp ) & webcam ?
because i want counting vehicle & person at red light intersection
regards,
rnd
Hi rnd,
We observed that you have posted the same issue in another thread. Please refer to the answer here.
Megat
