6583 Discussions
Error AssertionFailed: !ieDims.empty() when apply pre-train model (Reinforcement Learning) on NCS2
LAndr23
I have a problem when I try to run my model Reinforcement Learning (RL) with LSTM on VPU (NCS2). It cannot load my network to the device (plugin = IEPlugin(device="MYRIAD")). But if I change device=CPU or GPU, It’ll work well.
This is my code I face the issue :
from openvino.inference_engine import IENetwork, IEPlugin
net = IENetwork(model=model_xml, weights=model_bin)
exec_net = plugin.load(network=net)
This is the error I got :
Traceback (most recent call last):
 File "NCS2_UTL_test.py", line 68, in <module>
 File "ie_api.pyx", line 1205, in openvino.inference_engine.ie_api.IEPlugin.load
 File "ie_api.pyx", line 1215, in openvino.inference_engine.ie_api.IEPlugin.load
RuntimeError: AssertionFailed: !ieDims.empty()
So, can you give me the reason and how can I fix it if I want to run it on VPU?
Thank you
RandallMan_B_Intel
Hi Andrew,
It seems like the layer is not supported by MYRIAD plugin; you can check that here. However, check this thread can be helpful.
Randall B.
LAndr23
Hi Randall B,
I tried to use the thread but it's still not working. You montioned the layer is not supported by MYRIAD, so how can I show exactly what's the name of layer is not supported?
LAndr23
Additionly, This's my error I got when trying to through the xml replacing :
<output>
                <port id="1" precision="I64"/>
</output>
To
            <output>
                <port id="1" precision="I64">
                    <dim>1</dim>
                </port>
            </output>
 File "NCS2_UTL_test.py", line 59, in <module>
 File "ie_api.pyx", line 980, in openvino.inference_engine.ie_api.IENetwork.__cinit__
RuntimeError: Check 'axis_ps.rank().is_static() && (size_t)axis_ps.rank() == 0' failed at ..\ngraph\src\ngraph\op\fused\split.cpp:133:
While validating node 'Split[Split_148](Reshape_146: float{1,248}, Constant_147: int64_t{1}) -> (??)':
The 'axis' input is expected to be a scalar. Got: {1}
This error occurs both running on CPU device and VPU when changing the xml.
And I can still run on the CPU if I don't change the xml file according to your instructions.
RandallMan_B_Intel
Hi Andrew,
Unfortunately, the LSTM is not supported by the MYRIAD plugin (NCS2).
Let me know if you have additional questions.
Randall B.
