I am conducting an experiment according to 6.6. Programming the FPGA Device
I have run init_env.sh and setupvars.sh and other environment settings, and I can see the COREDLA_ROOT environment variable by typing env in the terminal
But when I execute the command ./build_runtime -de10_agilex in /opt/intel/fpga_ai_suite_2024.1/dla/runtime, an error still occurs:
Error:COREDLA_ROOT environment variable not set.Run inti_env.sh script first.
Any help would be greatly appreciated, thank you!
Hi STATEABC,
Referring to Setting Required Environment Variables, could you please run the following command and see if the issue can be resolved?
unalias ls 2> /dev/null
source /opt/intel/openvino_2022/setupvars.sh
source /opt/intel/fpga_ai_suite_2024.1/dla/bin/init_env.sh
For more information, please refer to FPGA AI Suite Quick Start Tutorial
Wan
Hi STATEABC,
Wan
Hi STATEABC,
Thanks for your question.
This case will no longer be monitored since the issue has been resolved. If you need additional information from Intel, please submit a new question.
Wan
