Error Converting BERT Onnx Model
Ray_Lo_Intel
I'm trying to convert the BERT model based on this documentation ...
https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_ONNX.html
python3 mo.py --input_model <INPUT_MODEL>.onnx
So, apparently the BERT link is broken,
Then, I visited
and linked me to onnx model here.
Finally, I ran the command and then it got this. Any ideas? Thank you.
rlo@rlo-mac01 Desktop % python3 /opt/intel/openvino_2021.1.110/deployment_tools/model_optimizer/mo.py --input_model ~/Downloads/model.onnx
Model Optimizer arguments:
Common parameters:
	- Path to the Input Model: 	/Users/rlo/Downloads/model.onnx
	- Path for generated IR: 	/Users/rlo/Desktop/.
	- IR output name: 	model
	- Log level: 	ERROR
	- Batch: 	Not specified, inherited from the model
	- Input layers: 	Not specified, inherited from the model
	- Output layers: 	Not specified, inherited from the model
	- Input shapes: 	Not specified, inherited from the model
	- Mean values: 	Not specified
	- Scale values: 	Not specified
	- Scale factor: 	Not specified
	- Precision of IR: 	FP32
	- Enable fusing: 	True
	- Enable grouped convolutions fusing: 	True
	- Move mean values to preprocess section: 	None
	- Reverse input channels: 	False
ONNX specific parameters:
Model Optimizer version: 	2021.1.0-1237-bece22ac675-releases/2021/1
[libprotobuf ERROR google/protobuf/descriptor_database.cc:394] Invalid file descriptor data passed to EncodedDescriptorDatabase::Add().
[libprotobuf FATAL google/protobuf/descriptor.cc:1356] CHECK failed: GeneratedDatabase()->Add(encoded_file_descriptor, size):
libc++abi.dylib: terminating with uncaught exception of type google::protobuf::FatalException: CHECK failed: GeneratedDatabase()->Add(encoded_file_descriptor, size):
zsh: abort      python3 /opt/intel/openvino_2021.1.110/deployment_tools/model_optimizer/mo.py
Ray_Lo_Intel
Ok I made some progress, and apparently I have to uninstall tensorflow ...
pip3 uninstall tensorflow
I'm on Mac OSX 10.15.7 and Python 3.7.9
And then I can convert the model based on this now.
https://docs.openvinotoolkit.org/latest/omz_demos_python_demos_bert_question_answering_demo_README.html
But with the tensorflow installed, this always happens! and I can run
python3 -c 'import tensorflow' without triggering any errors.
rlo@rlo-mac01 Desktop % python3  /opt/intel/openvino_2021.1.110/deployment_tools/model_optimizer/mo.py -m ~/Downloads/bert_large_v1_1_fake_quant.onnx --input "input_ids,attention_mask,token_type_ids" --input_shape "[1,384],[1,384],[1,384]" --keep_shape_ops
[ WARNING ]  Use of removed cli option '--keep_shape_ops' detected. The option is ignored.
Common parameters:
	- Path to the Input Model: 	/Users/rlo/Downloads/bert_large_v1_1_fake_quant.onnx
	- IR output name: 	bert_large_v1_1_fake_quant
	- Log level: 	ERROR
	- Input layers: 	input_ids,attention_mask,token_type_ids
	- Input shapes: 	[1,384],[1,384],[1,384]
JesusE_Intel
Hi @Ray_Lo_Intel
What version of protobuf are you using? Using the same model optimizer command, I was able to convert this model successfully with OpenVINO toolkit 2021.1 on MacOS 10.14.6, Python 3.6.5 and Protobuf 3.13.0. Try re-installing protobuf and see if that helps.
Jesus
IntelSupport
Community Manager
Hi Raymond,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Adli
