gError installing openvino 2021.1.110
beltramo__enrico
Installing the latest version of Openvino (2021.1.110) following steps:
https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_linux.html
I have follow error when I run setupvars:
[setupvars.sh] ERROR: Can not find OpenVINO Python module for python3.8 by path /opt/intel/openvino_2021/python/python3.8
Rizal_Intel
Hi beltramo,
Currently, the OpenVINO 2021.1 LINUX distribution have no modules for python 3.8.
I would recommend you use python 3.7 as an alternative for now.
Rizal
beltramo__enrico
Is not clear for me witch version of python is looking the setupvars file. In my system I'm running  python with a conda installation.
I have to create a new conda env with python 3.7 and run the setupvars in it?
Looking in the script, I noticed that is possible to start it with option -pyver, so starting it with option -pyver 3.7 inside a conve env 3.7, I have no error. Is that correct?
Rizal_Intel
Hi beltramo,
Yes, that is correct.
Don't forget to run OpenVINO python scripts with the same version of python (Python3.7 in your case).
Rizal
Rizal_Intel
Hi Beltramo,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Rizal
