6597 Discussions
Error - Could not open NCS device. mvncStatus value: -7
Hi, Movidius engineer
These days I've test Movidius NCS on my raspberry pi.
My test demo is ncsdk/examples/apps/hello_ncs_cpp
I've checked
$ ls /usr/local/lib/mvnc/
MvNCAPI.mvcmd libmvnc.so.0
But I still got the wrong mvncStatus value.
Could you give me some suggestions?
@AaronYue It seems like maybe the installation may have not completed successfully. Can you try re-cloning and reinstalling the NCSDK again?
Yes, I've tried it again but still failed.
I compiled ncsdk/examples/apps/hello_ncs_cpp and then executed it.
Then I inserted the NCS to raspberry pi.
Here are the logs I got.
$ ./ncs_test
I've checked again:
How to fix it?
@AaronYue Let's see if your RPi is detecting the NCS device. Can you try the following commands and post your log here?
  1. Unplug your NCS device.
  2.
  3. sudo dmesg -C
  4.
  5. Plug your NCS device back into your RPi.
  6.
  7. dmesg >> dmesg_log.txt
  8.
  9. Paste the contents of the dmesg_log.txt log here.
  10.
