I am running Ubuntu 16.04 on Virtualbox.
I've downloaded SDK version 1 and version 2 seperately to see if my NCS works.
When ever I run "make example", I hear USB being unplugged. Then, the make process stops with Error 7.
When running "make run" in hello_ncs_py directory. I again hear USB being unplugged.
I have followed the instructions (https://movidius.github.io/ncsdk/vm_config.html) but it did not help out.
Any pointers? Thanks in advance.
PS. I've read through most of "Error 7" related or "cloud not open NCS device" threads here. My devices is working fine. ran though "lsusb" and "dmesg" to check.
Hi @spencer
Did you setup the USB filters in the VirtualBox machine settings? I found that I also had to install the VirtualBox Extension Pack on Virtualbox. Once the extension pack was installed, I also loaded guest additions to the guest machine.
- Start the Guest Machine
- Devices -> Insert Guest Additions CD image…
- Follow the prompt instructions
- Reboot the Guest Machine
Hope this helps!
Jesus
Thanks Jesus.
I've followed your instructions but did not work. I couldn't find a way around with this issue.
Hi @spencer
Are you using a USB hub? If you are, try using a powered USB hub or plugging into a different port.
Since you verified your NCS device is working, this might be a device re-enumeration bug with the NCSDK and VM that we are working on at the moment. We will let you know as soon as we figure out a solution!
Sahira
I'm running Ubuntu 16.04 natively and I'm also getting the same error "Error - Could not open NCS device."
There are numerous suggestions scattered all over and none of them seems to work.
This is a deal-breaker. Kindly fix it and also give us a central place to find WORKING instructions on getting this stuff to work.
I was so excited to purchase one, but now…
And just like @spencer , I see the device listed when I run lsusb or dmesg.
Also, I'm able to use the api to enumerate device but I get the same error message when I invoke 'open' on the device.
I have all the information in both filters as above.
Tired on USB3 computer ports
Tried on powered USB3 hub.
$ making run
python3 hello_ncs.py;
D : [ 0] ncDeviceCreate:308 ncDeviceCreate index 0
D : [ 0] ncDeviceCreate:308 ncDeviceCreate index 1
D : [ 0] ncDeviceOpen:524 File path /usr/local/lib/mvnc/MvNCAPI-ma2450.mvcmd
I : [ 0] ncDeviceOpen:530 ncDeviceOpen() XLinkBootRemote returned success 0
W : [ 0] ncDeviceOpen:565 failed to find device
Just tried it on USB2 on the hub
$ making run
I: [ 0] ncDeviceOpen:530 ncDeviceOpen() XLinkBootRemote returned success 0
I: [ 0] ncDeviceOpen:568 XLinkConnect done - link Id 0
D : [ 0] ncDeviceOpen:582 done
I: [ 0] ncDeviceOpen:584 Booted 2-ma2450 -> VSC
I: [ 0] getDevAttributes:383 Device attributes
I: [ 0] getDevAttributes:386 Device FW version: 2.8.2450.16e
I: [ 0] getDevAttributes:388 mvTensorVersion 2.8
I: [ 0] getDevAttributes:389 Maximum graphs: 10
I: [ 0] getDevAttributes:390 Maximum fifos: 20
I: [ 0] getDevAttributes:392 Maximum graph option class: 1
I: [ 0] getDevAttributes:394 Maximum device option class: 1
I: [ 0] getDevAttributes:395 Device memory capacity: 522059056
Hello NCS! Device opened normally.
I: [ 0] ncDeviceClose:776 closing device
E: [ 0] dispatcherEventReceive:236 dispatcherEventReceive() Read failed -1
E: [ 0] eventReader:254 Failed to receive event, the device may have reset
Goodbye NCS! Device closed normally.
NCS device working.
USB2
$make examples
Blob generated
USB: Transferring Data…
E: [ 0] dispatcherEventSend:820 Write failed -1
Update:
To eliminate the use of Virtualbox as a problem, I unplugged all drives, installed a new SSD installed Unbuntu 16.4
$ apt-get install git
$ git clone -b ncsdk2 http://github.com/Movidius/ncsdk
$ cd ncsdk
$ sudo update-usbids
$ lsusb
$ make install
Same error but this time, but it got further than before.
Under VirtualBox failed here:
Network Input tensors ['data#24']
Network Output tensors ['prob#38']
Blob generated
Time to Execute : 97.19 ms
USB: Myriad Execution Finished
Time to Execute : 92.61 ms
Output is in Channel Minor format
USB: Myriad Connection Closing.
USB: Myriad Connection Closed.
Network Summary
Detailed Per Layer Profile
Under clean install of Unbuntu 16.4 USB3 powered hub
Network Input tensors ['data#143']
Network Output tensors ['prob#227']
Blob generated
W: [ 0] ncDeviceOpen:528 ncDeviceOpen() XLinkBootRemote returned error 3
[Error 7] Toolkit Error: USB Failure. Code: Error opening device
Makefile:65: recipe for target 'profile' failed
make[3]: *** [profile] Error 255
make[3]: Leaving directory '/home/michael/ncsdk/examples/caffe/GoogLeNet'
Makefile:12: recipe for target 'GoogLeNet' failed
make[2]: *** [GoogLeNet] Error 2
make[2]: Leaving directory '/home/michael/ncsdk/examples/caffe'
Makefile:12: recipe for target 'caffe/.' failed
make[1]: *** [caffe/.] Error 2
make[1]: Leaving directory '/home/michael/ncsdk/examples'
Makefile:57: recipe for target 'examples' failed
make: *** [examples] Error 2
$ making run
I: [ 0] ncDeviceOpen:584 Booted 9.2-ma2450 -> VSC
Installed all get updates
Installed NVIDIA Driver
Restarted
Plugged into USB3 port
Finally COMPLETED $ make examples
Later I will.
Re-run to see if it was a fluke
If its working, I will try it back in the USB3 hub to see if that's why it failed first time (after clean install not runing in VirtualBox)
If its working on both.
I will try VirtualBox again
Previously I did get updates in the VirtualBox
The only thing I didn't do was install NVIDIA Driver (but don't see how that could be related)
$ make examples fails
Update to VirtualBox 6
Use existing Unbuntu image and changed nothing.
Ran $ make examples - worked
Shut down Virtual Box
Ran $ make examples again - worked
So it was either:
Running it in a non VirtualBox once fixed it
Updating to VirtualBox 6 fixed it.
So I will put this one down to a VirtualBox issue.
Hi Everyone,
Jumping in on this thread because of the thread subject, [Error 7] Toolkit Error: USB Failure. Code: No devices found
I'm running:
VirtualBox 6.0.4
Ubuntu 16.04 desktop (clean install)
Initial instructions based on this page: https://medium.freecodecamp.org/how-to-set-up-the-intel-movidius-neural-compute-stick-b9db16d493a7
Followed instructions on this thread
make install - no problems
make examples - only error I get is: [Error 7] Toolkit Error: USB Failure. Code: No devices found
lsusb shows Bus 001 Device 004: ID 03e7:2485
cd over to ./examples/apps/hello_ncs_py
make run
Error - no NCS devices detected, verify an NCS device is connected.
Please let me know if there are any suggestions.
Thank you for your help.
Hi @Jeff_Blumenthal
Thank you for reaching out. Looking at your lsusb output Bus 001 Device 004: ID 03e7:2485, I can see that you are using an Intel Neural Compute Stick 2 (NCS 2). The Neural Compute SDK only has support for the original Neural Compute Stick. You will need to use the OpenVINO toolkit with your NCS 2.
Take a look at the getting started page for the NCS 2.
Jesus
Hi @Jesus_at_Intel,
Thank you for your help. I'm up and running on windows 10. Thank you for your help.
Jeff
