6575 Discussions
Error: Could not register C function: PublishKernels make sure your custom layer plugin is correct!
Deepak_C_R
I am getting following error:
/home/deepak//deployment_tools/model_optimizer/bin/ModelOptimizer -w /home/deepak/yoloTiny/yoloData/yolo-tiny.caffemodel -d /home/deepak/yoloTiny/yoloData/yolo-tiny.prototxt  -p FP32 -f 1 -b 1 --target APLK -o /home/deepak/yoloTiny/Code/generated/ -c -k /home/deepak/yoloTiny/Code/registration/
Start working...
Framework plugin: CAFFE
Target type: APLK
Network type: CLASSIFICATION
Batch size: 1
Precision: FP32
Layer fusion: true
Output directory: /home/deepak/yoloTiny/Code/generated/
Custom kernels directory: /home/deepak/yoloTiny/Code/registration/
Code generation mode: RELEASE
Network input normalization: 1
My Makefile contains following lines:
MAKE_SO: $(SO_SRC)
                $(CXX) -c cnn_custom_kernel_leaky_tensor_lib.cpp    $(INCLUDES) $(LIBS) -o cnn_custom_kernel_leaky_tensor_lib.o
                $(CXX) -c cnn_custom_kernel_module.cpp $(INCLUDES) $(LIBS) -o cnn_custom_kernel_module.o
                $(CXX) -c ./common/src/helper.cpp $(INCLUDES) $(LIBS) -o helper.o
                $(CXX) -shared cnn_custom_kernel_leaky_tensor_lib.o cnn_custom_kernel_module.o helper.o     $(INCLUDES) $(LIBS) -o $(LIBNAME)
MAKE_SO_LR:
                $(CCC) -c layers_registration/custom_layers_registration.c $(INCLUDES) $(LIBS) -o custom_layers_registration.o
                $(CCC) -shared custom_layers_registration.o $(INCLUDES) $(LIBS) -o layers_registration/libleaky_custom_layers.so
COPYCLXML:
         cp -f layers_registration/CustomLayersMapping.xml /home/deepak/deployment_tools/model_optimizer/bin/CustomLayersMapping.xml
         rm -fr registration/*.so
         cp layers_registration/libleaky_custom_layers.so registration/
EXECUTEMO:
         $(MO) -w $(MODELPATH) -d $(DEPLOYPATH)  -p FP32 -f 1 -b 1 --target APLK -o $(PWD)/generated/ -dm
         $(MO) -w $(MODELPATH) -d $(DEPLOYPATH)  -p FP32 -f 1 -b 1 --target APLK -o $(PWD)/generated/ -c -k $(PWD)/registration/
I have attached my custom_layers_registration.c file also.
558359
558360
Stav_S_Intel
Hi Deepak,
What HW are you running this on?
Stav
Deepak_C_R
Linux u 4.7.0.intel.r4.0 #1 SMP Fri Jun 30 21:30:59 IST 2017 x86_64 x86_64
Stav_S_Intel
Are you running this on Apolo Lake?
Stav
Deepak_C_R
No.
$lshw
uvpc002
    description: Desktop Computer
    product: To be filled by O.E.M. (To be filled by O.E.M.)
    vendor: Gigabyte Technology Co., Ltd.
    version: To be filled by O.E.M.
    serial: To be filled by O.E.M.
    width: 64 bits
    capabilities: smbios-2.8 dmi-2.8 vsyscall32
    configuration: boot=normal chassis=desktop family=To be filled by O.E.M. sku=To be filled by O.E.M. uuid=1C021B03-0D04-3F05-FE06-C10700080009
  *-core
       description: Motherboard
       product: H170M-DS3H-CF
       physical id: 0
       version: x.x
       slot: To be filled by O.E.M.
     *-firmware
          description: BIOS
          vendor: American Megatrends Inc.
          physical id: 0
          version: F4
          date: 03/07/2016
          capacity: 8128KiB
          capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int14serial int17printer acpi usb biosbootspecification uefi
     *-cache:0
          description: L1 cache
          physical id: 3d
          slot: L1 Cache
          capacity: 128KiB
          capabilities: synchronous internal write-back data
     *-cache:1
          physical id: 3e
          slot: L1 Cache
          capacity: 128KiB
          capabilities: synchronous internal write-back instruction
     *-cache:2
          description: L2 cache
          physical id: 3f
          slot: L2 Cache
          capacity: 1MiB
          capabilities: synchronous internal write-back unified
     *-cache:3
          description: L3 cache
          physical id: 40
          slot: L3 Cache
          capacity: 6MiB
     *-cpu
          description: CPU
          product: Intel(R) Core(TM) i5-6402P CPU @ 2.80GHz
          vendor: Intel Corp.
          physical id: 41
          bus info: cpu@0
          version: Intel(R) Core(TM) i5-6402P CPU @ 2.80GHz
          serial: To Be Filled By O.E.M.
          slot: U3E1
          capacity: 3386MHz
          width: 64 bits
          clock: 100MHz
          capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch intel_pt tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt xsaveopt xsavec xgetbv1 dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp cpufreq
          configuration: cores=4 enabledcores=4 threads=4
     *-memory
          description: System Memory
          physical id: 42
          slot: System board or motherboard
        *-bank:0
             description: [empty]
             physical id: 0
             slot: ChannelA-DIMM0
        *-bank:1
             description: DIMM Synchronous 2133 MHz (0.5 ns)
             product: V01D4LF8GB5285282133
             vendor: 0000
             physical id: 1
             serial: 00000000
             slot: ChannelA-DIMM1
             width: 64 bits
             clock: 2133MHz (0.5ns)
        *-bank:2
             physical id: 2
             slot: ChannelB-DIMM0
        *-bank:3
             vendor: 0000
             physical id: 3
             serial: 00000000
             slot: ChannelB-DIMM1
             width: 64 bits
     *-pci
          description: Host bridge
          product: Sky Lake Host Bridge/DRAM Registers
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 07
          width: 32 bits
          clock: 33MHz
          configuration: driver=skl_uncore
          resources: irq:0
        *-display
             description: VGA compatible controller
             product: Intel Corporation
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 06
             width: 64 bits
             clock: 33MHz
             capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
             configuration: driver=i915 latency=0
             resources: irq:124 memory:de000000-deffffff memory:c0000000-cfffffff ioport:f000(size=64) memory:c0000-dffff
        *-usb
             description: USB controller
             product: Sunrise Point-H USB 3.0 xHCI Controller
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 31
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:120 memory:df210000-df21ffff
        *-generic UNCLAIMED
             description: Signal processing controller
             product: Sunrise Point-H Thermal subsystem
             physical id: 14.2
             bus info: pci@0000:00:14.2
             version: 31
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi cap_list
             configuration: latency=0
             resources: memory:df22e000-df22efff
        *-communication
             description: Communication controller
             product: Sunrise Point-H CSME HECI #1
             physical id: 16
             bus info: pci@0000:00:16.0
             version: 31
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: driver=mei_me latency=0
             resources: irq:123 memory:df22d000-df22dfff
        *-storage
             description: SATA controller
             product: Sunrise Point-H SATA controller [AHCI mode]
             physical id: 17
             bus info: pci@0000:00:17.0
             version: 31
             width: 32 bits
             clock: 66MHz
             capabilities: storage msi pm ahci_1.0 bus_master cap_list
             configuration: driver=ahci latency=0
             resources: irq:121 memory:df228000-df229fff memory:df22c000-df22c0ff ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:df22b000-df22b7ff
        *-pci:0
             description: PCI bridge
             product: Sunrise Point-H PCI Root Port #19
             physical id: 1b
             bus info: pci@0000:00:1b.0
             version: f1
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:18
        *-pci:1
             product: Sunrise Point-H PCI Root Port #20
             physical id: 1b.3
             bus info: pci@0000:00:1b.3
             version: f1
             width: 32 bits
             clock: 33MHz
             resources: irq:19 memory:df100000-df1fffff
           *-network
                description: Wireless interface
                product: AR9485 Wireless Network Adapter
                vendor: Qualcomm Atheros
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: wlan0
                version: 01
                serial: d4:6e:0e:06:e7:50
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical wireless
                configuration: broadcast=yes driver=ath9k driverversion=4.7.0.intel.r4.0 firmware=N/A ip=192.168.223.102 latency=0 link=yes multicast=yes wireless=IEEE 802.11
                resources: irq:19 memory:df100000-df17ffff memory:df180000-df18ffff
        *-pci:2
             product: Sunrise Point-H PCI Express Root Port #3
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: f1
             width: 32 bits
             clock: 33MHz
             resources: irq:18 ioport:e000(size=4096) memory:df000000-df0fffff
           *-network
                description: Ethernet interface
                product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:03:00.0
                logical name: eth0
                version: 15
                serial: 1c:1b:0d:3f:fe:c1
                capacity: 1Gbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.1.40 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
                resources: irq:122 ioport:e000(size=256) memory:df004000-df004fff memory:df000000-df003fff
        *-pci:3
             product: Sunrise Point-H PCI Express Root Port #5
             physical id: 1c.4
             bus info: pci@0000:00:1c.4
             version: f1
             width: 32 bits
             clock: 33MHz
             resources: irq:16
        *-pci:4
             product: Sunrise Point-H PCI Express Root Port #9
             physical id: 1d
             bus info: pci@0000:00:1d.0
             version: f1
             width: 32 bits
             clock: 33MHz
             resources: irq:16
        *-pci:5
             product: Sunrise Point-H PCI Express Root Port #13
             physical id: 1d.4
             bus info: pci@0000:00:1d.4
             version: f1
             width: 32 bits
             clock: 33MHz
             resources: irq:16
        *-isa
             description: ISA bridge
             product: Sunrise Point-H LPC Controller
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 31
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master
        *-memory UNCLAIMED
             description: Memory controller
             product: Sunrise Point-H PMC
             physical id: 1f.2
             bus info: pci@0000:00:1f.2
             version: 31
             width: 32 bits
             clock: 33MHz (30.3ns)
             resources: memory:df224000-df227fff
        *-multimedia
             description: Audio device
             product: Sunrise Point-H HD Audio
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 31
             width: 64 bits
             clock: 33MHz
             configuration: driver=snd_hda_intel latency=32
             resources: irq:125 memory:df220000-df223fff memory:df200000-df20ffff
        *-serial UNCLAIMED
             description: SMBus
             product: Sunrise Point-H SMBus
             physical id: 1f.4
             bus info: pci@0000:00:1f.4
             version: 31
             width: 64 bits
             clock: 33MHz
             resources: memory:df22a000-df22a0ff ioport:f040(size=32)
     *-scsi
          physical id: 1
          logical name: scsi0
          capabilities: emulated
        *-disk
             description: ATA Disk
             product: ST2000DM006-2DM1
             vendor: Seagate
             physical id: 0.0.0
             bus info: scsi@0:0.0.0
             logical name: /dev/sda
             version: CC26
             serial: Z4Z8808K
             capabilities: gpt-1.00 partitioned partitioned:gpt
             configuration: ansiversion=5 guid=e0591db1-ec6e-450a-84f1-b77244c67cd4 sectorsize=4096
           *-volume:0
                description: Windows FAT volume
                vendor: mkfs.fat
                physical id: 1
                bus info: scsi@0:0.0.0,1
                logical name: /dev/sda1
                logical name: /boot/efi
                version: FAT32
                serial: 89df-2e1e
                capacity: 511MiB
                capabilities: boot fat initialized
                configuration: FATs=2 filesystem=fat mount.fstype=vfat mount.options=rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro name=EFI System Partition state=mounted
           *-volume:1
                description: EXT4 volume
                vendor: Linux
                physical id: 2
                bus info: scsi@0:0.0.0,2
                logical name: /dev/sda2
                logical name: /
                version: 1.0
                serial: e6dbee7d-1627-4235-9c00-31a83c740888
                capabilities: journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
                configuration: created=2017-06-30 20:19:41 filesystem=ext4 lastmountpoint=/ modified=2017-07-28 10:04:42 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,data=ordered mounted=2017-07-28 10:04:42 state=mounted
           *-volume:2
                description: Linux swap volume
                vendor: Linux
                physical id: 3
                bus info: scsi@0:0.0.0,3
                logical name: /dev/sda3
                version: 1
                serial: a55e2ded-3bc1-443e-b006-1a3b422dfe2e
                capacity: 15GiB
                capabilities: nofs swap initialized
                configuration: filesystem=swap pagesize=4095
  *-power UNCLAIMED
       description: To Be Filled By O.E.M.
       product: To Be Filled By O.E.M.
       vendor: To Be Filled By O.E.M.
       physical id: 1
       version: To Be Filled By O.E.M.
       capacity: 32768mWh
Stav_S_Intel
Hi Deepak,
You target HW is currently APL, you need to change the target in the configurations of MO.
Stav
Deepak_C_R
Hi Stav,
Currently I am using --target APLK. Which one do I need to use ?
