Error Executing Ported Model in OpenVino
A__Siva
#1. Trained a Pytorch Model
#2. Converted it into ONNX format. Conversion to ONNX format is successful No Errors
#3. Used OpenVino Option to get the XML using Model Optimizer. The Model Optimizer Generates Required XML No Errors. All the layers mentioned in XML are Supported by OpenVino.
#4. Got this error while running the demo - [ERROR] MKLDNNGraph::CreateGraph: such topology cannot be compiled for dynamic batch.
With the XML this error cannot be compiled for dynamic batch returned
Any thoughts / suggestion to take it forward ?
Shubha_R_Intel
Dear Siva,
My guess is that your ONNX model has a layer which is not supported by Dynamic Batching. Or maybe you're trying to run this on MYRIAD - which is a problem since Dynamic Batching is only supported on CPU and GPU. Can you kindly check this documentation to see how its content may apply to your situation ? I'm not sure which demo you are running, but does it set KEY_DYN_BATCH_ENABLED as described in the code below?
https://docs.openvinotoolkit.org/latest/_docs_IE_DG_DynamicBatching.html
Shubha
