6605 Discussions
Error compiling horizontal-text-detection-0001 model by myriad_compiler
asidsunrise
Hello! I have some problems compiling Intel pre-trained model for text detection
(https://docs.openvinotoolkit.org/2021.2/omz_models_intel_horizontal_text_detection_0001_description_horizontal_text_detection_0001.html).
The error is "get_element_type() must be called on a node with exactly one output."
Other text detection models compile successfully. Is it a bug or I do something wrong? Screenshot is below the post. Thank You!
Azizul_Intel
Hi Alexey,
The model (horizontal-text-detection-0001.xml) does not work on MyriadX due to some layers are not implemented. Thus, you are seeing the indicated error with no .blob file generated.
Azizul
Iffa_Intel
According to your screenshot, it's just a Warning & shouldn't be a problem.
I recommend for you to use compile_tool instead and specify the device type (-d MYRIAD).
You can refer to my attachment.
asidsunrise
Thanks for the quick response! I executed the same code with compiler_tool and got the same output is in your terminal screenshot. But the .blob file for this model was not created (like it was with models text-detection-0003 and -0004). Was it created in your case?
Azizul_Intel
Hi Alexey,
Azizul
asidsunrise
Azizul_Intel
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Azizul
