6573 Discussions
Error importing Caffe , when typing the command 'make examples' . Using intel neural stick 2
Hi ,
I'm using the intel neural stick 2 along with raspberry pi with a camera attached for object detection.
I install and clone the ncsdk v. 1 and run make install and it installs fine.
When i run the command make examples I get the following error
What should i do to remove this error, please help !
`make examples ./install-opencv.sh OpenCV already setup for python make examples starting. (cd examples; make) make[1]: Entering directory '/home/pi/workspace/ncsdk/examples' make -C apps/. make[2]: Entering directory '/home/pi/workspace/ncsdk/examples/apps' make -C hello_ncs_py/. make[3]: Entering directory '/home/pi/workspace/ncsdk/examples/apps/hello_ncs_py' nothing to make, use 'make run' to run. make[3]: Leaving directory '/home/pi/workspace/ncsdk/examples/apps/hello_ncs_py' make -C multistick_cpp/. make[3]: Entering directory '/home/pi/workspace/ncsdk/examples/apps/multistick_cpp' making googlenet (cd ../../caffe/GoogLeNet; make compile; cd ../../apps/multistick_cpp; cp ../../caffe/GoogLeNet/graph ./googlenet.graph;) make[4]: Entering directory '/home/pi/workspace/ncsdk/examples/caffe/GoogLeNet' making prereqs (cd ../../data/ilsvrc12; make) make[5]: Entering directory '/home/pi/workspace/ncsdk/examples/data/ilsvrc12' --2019-03-22 09:00:32-- https://raw.githubusercontent.com/BVLC/caffe/master/data/ilsvrc12/get_ilsvrc_aux.sh Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.16.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.16.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 587 [text/plain] Saving to: ‘get_ilsvrc_aux.sh’ get_ilsvrc_aux.sh 100%[=============================================================================>] 587 --.-KB/s in 0s 2019-03-22 09:00:32 (4.28 MB/s) - ‘get_ilsvrc_aux.sh’ saved [587/587] Downloading... --2019-03-22 09:00:33-- http://dl.caffe.berkeleyvision.org/caffe_ilsvrc12.tar.gz Resolving dl.caffe.berkeleyvision.org (dl.caffe.berkeleyvision.org)... 169.229.222.251 Connecting to dl.caffe.berkeleyvision.org (dl.caffe.berkeleyvision.org)|169.229.222.251|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 17858008 (17M) [application/octet-stream] Saving to: ‘caffe_ilsvrc12.tar.gz’ caffe_ilsvrc12.tar.gz 100%[=============================================================================>] 17.03M 5.12MB/s in 4.0s 2019-03-22 09:00:37 (4.26 MB/s) - ‘caffe_ilsvrc12.tar.gz’ saved [17858008/17858008] Unzipping... Done. --2019-03-22 09:00:41-- https://raw.githubusercontent.com/BVLC/caffe/master/python/caffe/imagenet/ilsvrc_2012_mean.npy Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.16.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.16.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 1572944 (1.5M) [application/octet-stream] Saving to: ‘ilsvrc_2012_mean.npy’ ilsvrc_2012_mean.npy 100%[=============================================================================>] 1.50M 3.93MB/s in 0.4s 2019-03-22 09:00:41 (3.93 MB/s) - ‘ilsvrc_2012_mean.npy’ saved [1572944/1572944] make[5]: Leaving directory '/home/pi/workspace/ncsdk/examples/data/ilsvrc12' making prototxt Downloading Prototxt file --2019-03-22 09:00:42-- https://raw.githubusercontent.com/BVLC/caffe/master/models/bvlc_googlenet/deploy.prototxt Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.16.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.16.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 35862 (35K) [text/plain] Saving to: ‘./deploy.prototxt’ deploy.prototxt 100%[=============================================================================>] 35.02K --.-KB/s in 0.02s 2019-03-22 09:00:42 (1.61 MB/s) - ‘./deploy.prototxt’ saved [35862/35862] Adding input shape to prototxt file. making caffemodel Downloading caffemodel file --2019-03-22 09:00:42-- http://dl.caffe.berkeleyvision.org/bvlc_googlenet.caffemodel Resolving dl.caffe.berkeleyvision.org (dl.caffe.berkeleyvision.org)... 169.229.222.251 Connecting to dl.caffe.berkeleyvision.org (dl.caffe.berkeleyvision.org)|169.229.222.251|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 53533754 (51M) [application/octet-stream] Saving to: ‘./bvlc_googlenet.caffemodel’ bvlc_googlenet.caffemodel 100%[=============================================================================>] 51.05M 5.47MB/s in 21s 2019-03-22 09:01:03 (2.48 MB/s) - ‘./bvlc_googlenet.caffemodel’ saved [53533754/53533754] making compile mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt mvNCCompile v02.00, Copyright @ Movidius Ltd 2016 Error importing caffe make[4]: Leaving directory '/home/pi/workspace/ncsdk/examples/caffe/GoogLeNet' cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory Makefile:9: recipe for target 'googlenet' failed make[3]: *** [googlenet] Error 1 make[3]: Leaving directory '/home/pi/workspace/ncsdk/examples/apps/multistick_cpp' Makefile:12: recipe for target 'multistick_cpp/.' failed make[2]: *** [multistick_cpp/.] Error 2 make[2]: Leaving directory '/home/pi/workspace/ncsdk/examples/apps' Makefile:12: recipe for target 'apps/.' failed make[1]: *** [apps/.] Error 2 make[1]: Leaving directory '/home/pi/workspace/ncsdk/examples' Makefile:57: recipe for target 'examples' failed make: *** [examples] Error 2
Hi @Osama1995 ,
Thanks for reaching out. Unfortunately the NCSDK does not have support for the NCS2, to be able to use the NCS2 you may need to download and install the OpenVINO toolkit. You can find all the relevant information and links to the getting-started guide on this post here. Please let me know if you have any additional questions.
@Luis_at_Intel
