- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I've searched all methods through the website and it took me almost ONE day, but it seems not work.
I checked the numpy path, upgraded it, and added the caffe path to $PYTHONPATH……
Hope some expert could help. Thx very much! Here is the compile result:
pi@raspberrypi:~/ncsexp/ncappzoo/caffe/TinyYolo $ make compile
making prototxt
Prototxt file already exists
making caffemodel
caffemodel file already exists
making compile
mvNCCompile -o graph -w tiny-yolo-v1_53000.caffemodel -s 12 tiny-yolo-v1.prototxt
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
Error importing caffe
pi@raspberrypi:~/ncsexp/ncappzoo/caffe/TinyYolo $ echo $PYTHONPATH
/opt/movidius/caffe/python:
pi@raspberrypi:~/ncsexp/ncappzoo/caffe/TinyYolo $ python3
Python 3.5.3 (default, Sep 27 2018, 17:25:39)
[GCC 6.3.0 20170516] on linux
Type "help", "copyright", "credits" or "license" for more information.
import caffe
Traceback (most recent call last):
File "", line 1, in
File "/opt/movidius/caffe/python/caffe/init.py", line 1, in
from .pycaffe import Net, SGDSolver, NesterovSolver, AdaGradSolver, RMSPropSolver, AdaDeltaSolver, AdamSolver
File "/opt/movidius/caffe/python/caffe/pycaffe.py", line 15, in
import caffe.io
File "/opt/movidius/caffe/python/caffe/io.py", line 2, in
import skimage.io
File "/usr/local/lib/python3.5/dist-packages/skimage/init.py", line 167, in
from .util.dtype import (img_as_float32,
File "/usr/local/lib/python3.5/dist-packages/skimage/util/init.py", line 8, in
from .arraycrop import crop
File "/usr/local/lib/python3.5/dist-packages/skimage/util/arraycrop.py", line 8, in
from numpy.lib.arraypad import _validate_lengths
ImportError: cannot import name '_validate_lengths'
- Balises:
- Caffe
Lien copié
1 Répondre
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hey guys…I've solved the problem by adding two function in numpy.lib.arraypad for realizing the '_validate_lengths'. Thx!
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
