6594 ディスカッション
Error in the last step of building OpenVINO runtime for Mac
hongbo-wei
初心者
2,204件の閲覧回数
I want to build OpenVINO runtime to test my contributed program for MatrixInverse - GitHub Issue 22957 , and I follow the instructions in Mac (ARM)
In the second last step, I run
cmake -G "Ninja Multi-Config" -DENABLE_SYSTEM_PUGIXML=ON -DENABLE_SYSTEM_SNAPPY=ON -DENABLE_SYSTEM_PROTOBUF=ON ..
and was told that couldn't find Protobuf even it is installed using `brew`. I therefore concatenated `-DPROTOBUF_LIBRARY=~/opt/homebrew/opt/protobuf` in the command, and run it. No error.
In the last step I encountered an error that says `'protobuf::libprotobuf-NOTFOUND'`.
ninja: error: 'protobuf::libprotobuf-NOTFOUND', needed by '/Users/hongbo_wei/downloads/GitHub/openvino/bin/arm64/Release/libopenvino_tensorflow_frontend.2024.2.0.dylib', missing and no known rule to make it
0 件の賞賛
6 返答(返信)
hongbo-wei
初心者
2,153件の閲覧回数
I then set the environment path for CMake using the right path to protobuf, but the build system still cannot find it
export CMAKE_PREFIX_PATH=/opt/homebrew/opt/protobuf
export CMAKE_LIBRARY_PATH=/opt/homebrew/opt/protobuf
Wan_Intel
モデレーター
2,105件の閲覧回数
Hi Hongbo-wei,
Could you please share the following information with us so that we can further investigate the issue?
  • Version of macOS
  • Version of Python
  • Hardware
Wan
hongbo-wei
初心者
2,092件の閲覧回数
@Wan_Intel
  • Version of macOS - 14.4.1 (23E224)
  • Version of Python - 3.11.0
  • Hardware - Apple M2 Max (ARM 64)
    Thank you for helping me!
Wan_Intel
モデレーター
2,053件の閲覧回数
Hi Hongbo-wei,
Thanks for sharing the information.
We'll investigate the issue and update you as soon as possible. Sorry for the inconvenience and thank you for your support.
Wan
Wan_Intel
モデレーター
1,920件の閲覧回数
Hi Hongbo-wei,
Thanks for your patience.
For your information, we noticed that you’ve opened a similar question at the following GitHub thread:
https://github.com/openvinotoolkit/openvino/issues/22957
On another note, OpenVINO™ GitHub developer closed the GitHub thread above as completed and mentioned the issue was fixed in the following pull request:
https://github.com/openvinotoolkit/openvino/pull/23881
Hope it helps.
Wan
Wan_Intel
モデレーター
1,596件の閲覧回数
Hi Hongbo-wei,
If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
返信
