Error on Output Tensor
Hi, in this session get this kind of error:
mvNCCheck '/media/sf_NeuralNetwork/cat_inceptionSGD.pb' -in=input_1 -on=predictions/Softmax -s 12 /usr/local/bin/ncsdk/Controllers/Parsers/TensorFlowParser/Convolution.py:44: SyntaxWarning: assertion is always true, perhaps remove parentheses? assert(False, "Layer type not supported by Convolution: " + obj.type) mvNCCheck v02.00, Copyright @ Intel Corporation 2017 shape: [1, 139, 139, 3] Traceback (most recent call last): File "/usr/local/bin/mvNCCheck", line 202, in <module> quit_code = check_net(args.network, args.image, args.inputnode, args.outputnode, args.nshaves, args.inputsize, args.weights, args) File "/usr/local/bin/mvNCCheck", line 169, in check_net load_ret = load_network(args, parser, myriad_config) File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 100, in load_network parse_ret = parse_tensor(arguments, myriad_conf) File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 1032, in parse_tensor output_size = [input_shape[0], 1, 1, outputs[3]] File "/home/francesco/.local/lib/python3.5/site-packages/tensorflow/python/framework/tensor_shape.py", line 616, in __getitem__ return self._dims[key] IndexError: list index out of range
Configuration:
Linux Ubuntu 16.04 LTS
ncsdk v2.08
python 3.5.2
TensorFlow 1.10.0
