6597 Discussions
Error: runvad.sh: 2: runvad.sh: Bad substitution
Deepak_C_R
I am getting following error while running VAD.
runvad.sh: 4: runvad.sh: source: not found
deepak@Desktop:/opt/intel/computer_vision_sdk_2017.0.113/vad$ sh runvad.sh
LD_LIBRARY_PATH=/opt/intel//computer_vision_sdk_2017.0.113/opencv/share/OpenCV/3rdparty/lib:/opt/intel//computer_vision_sdk_2017.0.113/opencv/lib:/opt/intel//computer_vision_sdk_2017.0.113/inference_engine/external/cldnn/lib:/opt/intel//computer_vision_sdk_2017.0.113/inference_engine/external/mklml_lnx/lib:/opt/intel//computer_vision_sdk_2017.0.113/mo/bin:/opt/intel//computer_vision_sdk_2017.0.113/openvx/lib:/opt/intel/deeplearning_deploymenttoolkit_2017.1.0.4463/deployment_tools/external/cldnn/lib:/opt/intel/deeplearning_deploymenttoolkit_2017.1.0.4463/deployment_tools/external/mklml_lnx/lib:/opt/intel//computer_vision_sdk_2017.0.113/opencv/share/OpenCV/3rdparty/lib:/opt/intel//computer_vision_sdk_2017.0.113/opencv/lib:/opt/intel//computer_vision_sdk_2017.0.113/inference_engine/external/cldnn/lib:/opt/intel//computer_vision_sdk_2017.0.113/inference_engine/external/mklml_lnx/lib:/opt/intel//computer_vision_sdk_2017.0.113/mo/bin:/opt/intel//computer_vision_sdk_2017.0.113/openvx/lib:/opt/intel/deeplearning_deploymenttoolkit_2017.1.0.4463/deployment_tools/external/cldnn/lib:/opt/intel/deeplearning_deploymenttoolkit_2017.1.0.4463/deployment_tools/external/mklml_lnx/lib:/opt/intel//computer_vision_sdk_2017.0.113/opencv/share/OpenCV/3rdparty/lib:/opt/intel//computer_vision_sdk_2017.0.113/opencv/lib:/opt/intel//computer_vision_sdk_2017.0.113/inference_engine/external/cldnn/lib:/opt/intel//computer_vision_sdk_2017.0.113/inference_engine/external/mklml_lnx/lib:/opt/intel//computer_vision_sdk_2017.0.113/mo/bin:/opt/intel//computer_vision_sdk_2017.0.113/openvx/lib:/opt/intel/deeplearning_deploymenttoolkit_2017.1.0.4463/deployment_tools/external/cldnn/lib:/opt/intel/deeplearning_deploymenttoolkit_2017.1.0.4463/deployment_tools/external/mklml_lnx/lib:/opt/intel//computer_vision_sdk_2017.0.113/opencv/share/OpenCV/3rdparty/lib:/opt/intel//computer_vision_sdk_2017.0.113/opencv/lib:/opt/intel//computer_vision_sdk_2017.0.113/inference_engine/external/cldnn/lib:/opt/intel//computer_vision_sdk_2017.0.113/inference_engine/external/mklml_lnx/lib:/opt/intel//computer_vision_sdk_2017.0.113/mo/bin:/opt/intel//computer_vision_sdk_2017.0.113/openvx/lib:/opt/intel/deeplearning_deploymenttoolkit_2017.1.0.4463/deployment_tools/external/cldnn/lib:/opt/intel/deeplearning_deploymenttoolkit_2017.1.0.4463/deployment_tools/external/mklml_lnx/lib::/opt/intel/computer_vision_sdk_2017.0.113/inference_engine/lib/ubuntu_16.04/intel64/:/opt/intel/computer_vision_sdk_2017.0.113/inference_engine/lib/ubuntu_16.04/intel64/:/usr/lib/x86_64-linux-gnu/hdf5/serial/:/opt/intel/computer_vision_sdk_2017.0.113/inference_engine/lib/ubuntu_16.04/intel64/:/usr/lib/x86_64-linux-gnu/hdf5/serial/:/home/deepak/caffe-master/distribute/lib/:/opt/intel/opencl/:/opt/intel/computer_vision_sdk_2017.0.113/inference_engine/lib/ubuntu_16.04/intel64/:/usr/lib/x86_64-linux-gnu/hdf5/serial/:/home/deepak/caffe-master/distribute/lib/:/opt/intel/opencl/
System details given below:
deepak@Desktop:~$ uname -a
Linux Desktop 4.10.0-30-generic #34~16.04.1-Ubuntu SMP Wed Aug 2 02:13:56 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
What could be the reason for the same ?
Anna_B_Intel
Hi Deepak,
Try to run vad in this way:
./runvad.sh
Best wishes,
Anna
Deepak_C_R
To run the application by sh runvad.sh we need to do as follows in Ubuntu.
In ubuntu by default it is /bin/dash we need to change that to /bin/bash (due to the presense of source command, which is not supported by dash command. If we are changing that to bash then it runs with sh command also.
$ls -l `which sh`
/bin/sh -> dash
$sudo dpkg-reconfigure dash #Select NO
$ls -l `which sh`
/bin/sh -> bash
