6597 Discussions
Exception: Status.MYRIADERROR when using fathom ncs and RPI3
I am trying to get the stream_infer example running with the older version of the ncs (i.e. the fathom stick) on the RPI3 with raspbian jessie OS.
I followed the getting started guide but when I run stream_infer I get the following output:
_*_Number of categories: 1000
Found stale device, resetting
Device 0 Address: 1.2 - VID/PID 03e7:2150
Starting wait for connect with 2000ms timeout
Found Address: 1.2 - VID/PID 03e7:2150
Found EP 0x81 : max packet size is 512 bytes
Found EP 0x01 : max packet size is 512 bytes
Found and opened device
Performing bulk write of 825136 bytes…
Successfully sent 825136 bytes of data in 34.520313 ms (22.795593 MB/s)
Boot successful, device address 1.2
Found Address: 1.2 - VID/PID 040e:f63b
done
Booted 1.2 -> VSC
Status.MYRIADERROR
Output thread terminating
Exception in thread Thread-1:
Traceback (most recent call last):
File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
self.run()
File "/usr/lib/python3.4/threading.py", line 868, in run
self._target(_self._args, *_self._kwargs)
File "stream_infer.py", line 149, in input_thread
gGraph.LoadTensor(preprocessed_image_buf ,"frame %s" % frame_number)
File "/usr/local/lib/python3.4/dist-packages/mvnc/mvncapi.py", line 194, in LoadTensor
raise Exception(Status(status))
Exception: Status.ERROR_*_
I was able to run the ncs-check example in the c_examples folder which successfully opened the device. However again when I tried to run the c examples on a network I get the following output:
_OpenDevice 1.2 succeeded
Press q to quit without closing, otherwise just
Graph allocated
GetResult failed, myriad error: This software supports Myriad2 revision C silicon only
Deallocate graph, rc=0
Device closed, rc=0_
Does this mean that the fathom ncs is not suitable for use with the RPI3?
The Fathom USB stick is intended to be used with SW packages up to Fathom_1.06.
SDK for RPi3 is actually v1.07 and works with NCS stick firmware which is different from that in FathomNCS. So this probably is causing incompatibility that you observe.
Hi georgievm_cms, Would I be able to download the previous version of the SDK(toolkit+api)(v1.06)? I can get v1.06 on fathom.ai/forum, however this sdk does not include the api or any of the python examples.
Hi, actually toolkit+api are released for the first time in v1.07. You can consider Fathom stick as a beta test version of the NCS. They are in fact two different products joined with their appropriate SW. Fathom SW up to 1.06 is intended only for Fathom stick; SDK v1.07 (and future versions) are usable with NCS only and not vice-versa.
