6575 Discussions
Error trying to download and convert yolo-v4-tf model
Jitendra_S_Intel
I tried in a jupyter notebook and directly in a terminal. Terminal output is pasted below
(openvino_2022.3.0) u73522@s099-n001:~$ omz_downloader --name yolo-v4-tf -o ~/Downloads/models
################|| Downloading yolo-v4-tf ||################
========== Downloading /home/u73522/Downloads/models/public/yolo-v4-tf/yolov4.weights
... 100%, 251677 KB, 67352 KB/s, 3 seconds passed
========== Downloading /home/u73522/Downloads/models/public/yolo-v4-tf/keras-YOLOv3-model-set/tools/model_converter/convert.py
... 100%, 16 KB, 39499 KB/s, 0 seconds passed
========== Downloading /home/u73522/Downloads/models/public/yolo-v4-tf/keras-YOLOv3-model-set/yolo4/models/layers.py
... 100%, 15 KB, 53637 KB/s, 0 seconds passed
========== Downloading /home/u73522/Downloads/models/public/yolo-v4-tf/keras-YOLOv3-model-set/cfg/yolov4.cfg
... 100%, 11 KB, 61731 KB/s, 0 seconds passed
========== Replacing text in /home/u73522/Downloads/models/public/yolo-v4-tf/keras-YOLOv3-model-set/yolo4/models/layers.py
(openvino_2022.3.0) u73522@s099-n001:~$ omz_converter --name yolo-v4-tf -o ~/Downloads/models
========== Running pre-convert script for yolo-v4-tf
Pre-convert command: /data/venv/openvino_2022.3.0/bin/python3.8 -- /data/venv/openvino_2022.3.0/lib/python3.8/site-packages/openvino/model_zoo/models/public/yolo-v4-tf/pre-convert.py -- /home/u73522/public/yolo-v4-tf /home/u73522/Downloads/models/public/yolo-v4-tf
/data/venv/openvino_2022.3.0/bin/python3.8: can't open file '/home/u73522/public/yolo-v4-tf/keras-YOLOv3-model-set/tools/model_converter/convert.py': [Errno 2] No such file or directory
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/openvino/model_zoo/models/public/yolo-v4-tf/pre-convert.py", line 40, in <module>
    main()
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/openvino/model_zoo/models/public/yolo-v4-tf/pre-convert.py", line 30, in main
    subprocess.run([sys.executable, '--',
  File "/usr/lib/python3.8/subprocess.py", line 512, in run
    raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['/data/venv/openvino_2022.3.0/bin/python3.8', '--', '/home/u73522/public/yolo-v4-tf/keras-YOLOv3-model-set/tools/model_converter/convert.py', '/home/u73522/public/yolo-v4-tf/keras-YOLOv3-model-set/cfg/yolov4.cfg', '/home/u73522/public/yolo-v4-tf/yolov4.weights', '/home/u73522/Downloads/models/public/yolo-v4-tf/yolo-v4.savedmodel', '--yolo4_reorder']' returned non-zero exit status 2.
FAILED:
yolo-v4-tf
Jitendra_S_Intel
I switched to openvino_2022.1.0.643 virtual env and was able to download and convert yolo-v4-tf using following steps:
omz_downloader --name yolo-v4-tf -o models
omz_converter --name yolo-v4-tf --output_dir models\irs --precisions FP16 -d models
omz_converter --name yolo-v4-tf --output_dir models\irs --precisions FP32 -d models
(openvino_2022.1.0.643) u73522@s099-n001:~/Downloads$
Hairul_Intel
Hi Jitendra_S_Intel,
For your information, I've validated from my end using OpenVINO 2022.3.0 and OpenVINO Jupyter Notebook. Both were successful in downloading and converting the yolo-v4-tf model. Here are the results:
Converting using openvino-dev[tensorflow2]:
Converting using openvino jupyter notebook:
On another note, the error log you've provided seems to indicate that 'yolo-v4-tf/keras-YOLOv3-model-set/tools/model_converter/convert.py' file was not found.
Please ensure the following file is available once you've ran the "omz_downloader --name yolo-v4-tf" command:
Hairul
Hairul_Intel
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Hairul
