Error using mvNCCompile
Hello!
I'm trying to implement the CNN multi view network in Movidius NCS (MVCNN image).
Is it possible to use an input for NCS of dimensions [Nviews, batch_size, im_l, im_w, Nchannels]?
I have tried to isolate the CNN1 network (Tensorboard graph in the image), and generate the Movidius .graph using:
mvNCCompile MVCNN.meta -s 12 -in im0 -on Reshape -o OutGraph.graph
I got the following error:
/home/cristian/tf/lib/python3.5/site-packages/tensorflow/python/framework/ops.py:858: DeprecationWarning: builtin type EagerTensor has no __module__ attribute EagerTensor = c_api.TFE_Py_InitEagerTensor(_EagerTensorBase) /home/cristian/tf/lib/python3.5/site-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead if d.decorator_argspec is not None), _inspect.getargspec(target)) /home/cristian/tf/lib/python3.5/site-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead if d.decorator_argspec is not None), _inspect.getargspec(target)) /home/cristian/tf/lib/python3.5/site-packages/tensorflow/python/framework/tensor_util.py:539: DeprecationWarning: The binary mode of fromstring is deprecated, as it behaves surprisingly on unicode inputs. Use frombuffer instead return np.fromstring(tensor.tensor_content, dtype=dtype).reshape(shape) Traceback (most recent call last): File "/usr/local/bin/mvNCCompile", line 118, in <module> create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights) File "/usr/local/bin/mvNCCompile", line 104, in create_graph net = parse_tensor(args, myriad_config) File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 298, in parse_tensor item_shape = output_item.shape.as_list() File "/home/cristian/tf/lib/python3.5/site-packages/tensorflow/python/framework/tensor_shape.py", line 809, in as_list raise ValueError("as_list() is not defined on an unknown TensorShape.") ValueError: as_list() is not defined on an unknown TensorShape.
The code of the original model is here:
https://github.com/WeiTang114/MVCNN-TensorFlow
My custom code is in Train.py
Thank you very much!
