6585 Discussions
Motion Detection/Estimation examples in OpenVINO, MediaSDK, OpenCL
sg
Hi,  I am trying to get a sense of the Motion Detection and Estimation examples in the above 3 software.   The MotionEstimation code in MediaSDK and OpenCL are same and apparently uses a build in accelerator called Video Motion Estimation. The OpenVINO motion detection code uses OpenVX graphs.  The outputs of the 2 are different also -  in the MediaSDK/OpenCL  example the output is an array  of motion vectors , in case of OpenVINO,   these are bounding boxes.
Would appreciate if someone can throw some light of the differences in input (YUV/RGB/MP4),  performance ( msec per fame ),  output ( array of vectors, bounding boxes ),  intended application (high level CV, vs low level video compression ).
