Error when convert onnx to openvino
Nguyen__Son
I'm running human pose estimation experiments from source code(https://github.com/opencv/openvino_training_extensions/blob/develop/pytorch_toolkit/human_pose_estimation/README_single.md).
I trained according to the author's instructions. The process of converting to onnx format also has no errors. However, when converting from onnx to openvino format, the following error occurs:
> Unexpected exception happened during extracting attributes for node 386.
Original exception message: Upsample mode bilinear for node 387 is not supported. Only nearest is supported.
> %387 : Float(1, 290, 16, 16) = onnx::Upsample[mode="bilinear"](%385, %386), scope: SinglePersonPoseEstimationWithMobileNet/RefinementStage/Sequential[trunk]/UShapedContextBlock[0]
I think the error is in the following code:
`        d2 = self.decoder2(torch.cat([e1, F.interpolate(e2, size=(16, 16),
                                                        mode='bilinear', align_corners=False)], 1))`
`        d1 = self.decoder1(torch.cat([x, F.interpolate(d2, size=(32, 32),
I changed mode to `nearest` but Pytorch support only: `linear`, `bilinear`, `trilinear`.
Shubha_R_Intel
Dear Nguyen, Son,
We have made some fixes to ONNX upsample in OpenVIno 2019R2. However bilinear mode is not supported, as you've observed. This github post also discusses the same issue.
I have filed a feature request to include bilinear mode to ONNX Upsample.
Sorry for the inconvenience !
Shubha
