Error when install NCSDK 2
Hi all,
I am using Ubuntu 16.04 LTS and trying to install the NCSDK 2 but it generates the error as below
Caffe not found, installing caffe…
/opt/movidius/ssd-caffe
HEAD is now at 4817bf8 Merge pull request #791 from eselkin/ssd
Already on 'ssd'
Your branch is up-to-date with 'origin/ssd'.
Already up-to-date.
Already on 'ssd'
Compiling Caffe…
-- The C compiler identification is GNU 5.4.0
-- The CXX compiler identification is GNU 5.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Boost version: 1.58.0
-- Found the following Boost libraries:
-- system
-- thread
-- filesystem
-- regex
-- chrono
-- date_time
-- atomic
-- Found gflags (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libgflags.so)
-- Found glog (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libglog.so)
CMake Error at /home/khuong/.local/lib/python3.5/site-packages/cmake/data/share/cmake-3.12/Modules/FindProtobuf.cmake:425 (file):
file STRINGS file
"/home/khuong/anaconda3/include/google/protobuf/stubs/common.h" cannot be
read.
Call Stack (most recent call first):
cmake/ProtoBuf.cmake:4 (find_package)
cmake/Dependencies.cmake:24 (include)
CMakeLists.txt:43 (include)
CMake Error at /home/khuong/.local/lib/python3.5/site-packages/cmake/data/share/cmake-3.12/Modules/FindProtobuf.cmake:431 (math):
math cannot parse the expression: " / 1000000": syntax error, unexpected
exp_DIVIDE, expecting exp_PLUS or exp_MINUS or exp_OPENPARENT or exp_NUMBER
(2)
CMake Error at /home/khuong/.local/lib/python3.5/site-packages/cmake/data/share/cmake-3.12/Modules/FindProtobuf.cmake:432 (math):
math cannot parse the expression: " / 1000 % 1000": syntax error,
unexpected exp_DIVIDE, expecting exp_PLUS or exp_MINUS or exp_OPENPARENT or
exp_NUMBER (2)
CMake Error at /home/khuong/.local/lib/python3.5/site-packages/cmake/data/share/cmake-3.12/Modules/FindProtobuf.cmake:433 (math):
math cannot parse the expression: " % 1000": syntax error, unexpected
exp_MOD, expecting exp_PLUS or exp_MINUS or exp_OPENPARENT or exp_NUMBER
(2)
-- Found Protobuf: /home/khuong/anaconda3/lib/libprotobuf.so;-lpthread (found version "..")
CMake Error at cmake/ProtoBuf.cmake:13 (message):
Could not find PROTOBUF Compiler
-- Configuring incomplete, errors occurred!
See also "/opt/movidius/ssd-caffe/build/CMakeFiles/CMakeOutput.log".
See also "/opt/movidius/ssd-caffe/build/CMakeFiles/CMakeError.log".
Installation failed. Error on line 678
Makefile:47: recipe for target 'install' failed
make: *** [install] Error 1
I have been trying many times but it stills failed at this error line 678. I would highly appreciate any help to resolve this
K
@KhuongTran89 I believe the conflict may be because of Anaconda because other users have reported similar issues. Try removing your Anaconda environment variable from bashrc then open a new terminal and try installing the NCSDK again. Alternatively, if possible try the NCSDK install on a clean machine.
