Error when running hello_query_device.py
Tenn__Hian-Kun
I've installed the OpenVINO R2 and started to try some the samples.
For the C++ version of "hello query device", everything was okay.
But when I tried to run the Python sample, it returned the following error message:
Traceback (most recent call last):
  File "hello_query_device.py", line 35, in <module>
    sys.exit(main() or 0)
  File "hello_query_device.py", line 30, in main
    cfg_val = ie.get_config(device, cfg)
  File "ie_api.pyx", line 124, in openvino.inference_engine.ie_api.IECore.get_config
TypeError: Failed to convert parameter to Python representation!
How could I fix it?
Shubha_R_Intel
Dear Tenn, Hian-Kun,
You are correct. I reproduced the same bug on OpenVino 2019R2.
I will file a bug on your behalf.
Sorry for the trouble !
Shubha
la__xl
same error here.
raspberry pi 3b+
	Default values for device configuration keys:
  File "/home/pi/inference_engine_vpu_arm_242/inference_engine/samples/python_samples/hello_query_device/hello_query_device.py", line 35, in <module>
  File "/home/pi/inference_engine_vpu_arm_242/inference_engine/samples/python_samples/hello_query_device/hello_query_device.py", line 30, in main
Shubha_R_Intel
Dear la, xl and everyone,
Thank you for your patience ! I have filed this bug on your behalf.
Shubha
