6574 Discussions
Error when running python script using the Open Vino Inference Engine on the Jupyter Notebook
Mwangi__Keith
Hello there, when i run this code on my Jupyter Notebook I'm getting this error
%%writefile person_detect.py
import numpy as np
import time
from openvino.inference_engine import IENetwork, IECore
import os
import cv2
import argparse
import sys
class Queue:
    Class for dealing with queues
    def __init__(self):
        self.queues=[]
    def add_queue(self, points):
        self.queues.append(points)
    def get_queues(self, image):
        for q in self.queues:
            x_min, y_min, x_max, y_max=q
            frame=image[y_min:y_max, x_min:x_max]
            yield frame
    def check_coords(self, coords):
        d={k+1:0 for k in range(len(self.queues))}
        for coord in coords:
            for i, q in enumerate(self.queues):
                if coord[0]>q[0] and coord[2]<q[2]:
                    d[i+1]+=1
        return d
class PersonDetect:
    Class for the Person Detection Model.
    def __init__(self, model_name, device, threshold=0.60):
        self.model_weights=model_name+'.bin'
        self.model_structure=model_name+'.xml'
        self.device=device
        self.threshold=threshold
        try:
            self.core = IECore()
            self.model = self.core.read_network(self.model_structure, self.model_weights)
        except Exception as e:
            raise ValueError("Could not Initialise the network. Have you enterred the correct model path?")
        self.input_name=next(iter(self.model.inputs))
        self.input_shape=self.model.inputs[self.input_name].shape
        self.output_name=next(iter(self.model.outputs))
        self.output_shape=self.model.outputs[self.output_name].shape
    def load_model(self):
        TODO: This method needs to be completed by you
        # load model
        self.net = self.core.load_network(network=self.model, device_name=self.device, num_requests=1)
        print("Network already loaded")
    def predict(self, image):
        input_image = image
        # name of the input node
        input_name = self.input_name
        # Preprocess the image
        proc_image = self.preprocess_input(image)
        input_dict = {input_name:proc_image}
        #start async inference
        print('Starting async inference')
        infer_request = self.net.start_async(request_id=0, inputs=input_dict)
        infer_status = infer_request.wait()
        if infer_status == 0:
            print('waiting for inference')
            output = infer_request.outputs[self.output_name]
            print('Obtain coords for thresholds')
            box = self.preprocess_outputs(output)
            print('Lets gooooooooo!')
        return self.draw_outputs(box, input_image)
        print('Its done')
    def draw_outputs(self, outputs, image):
        width = image.shape[1]
        height = image.shape[0]
        coords = []
        for box in outputs[0][0]:
            conf = box[2]
            if conf >= self.threshold:
                xmin = int(box[3] * width)
                ymin = int(box[4] * height)
                xmax = int(box[5] * width)
                ymax = int(box[6] * height)
                cv2.rectangle(image, (xmin,ymin), (xmax,ymax), (0,255,0), 1)
                coords.append((xmin, ymin, xmax, ymax))
        return coords, image
        print('Hello Keith')
    def preprocess_outputs(self, outputs):
        boxes = []
        for person in outputs[0][0]:
            if person[2] > self.threshold:
                boxes.append([person[3:]])
        return boxes
    def preprocess_input(self, image):
        image_p = cv2.resize(image, (self.input_shape[3], self.input_shape[2]))
        image_p = image_p.transpose((2,0,1))
        image_p = image_p.reshape(1, *image_p.shape)
        return image_p
def main(args):
    model=args.model
    device=args.device
    video_file=args.video
    max_people=args.max_people
    threshold=args.threshold
    output_path=args.output_path
    start_model_load_time=time.time()
    pd= PersonDetect(model, device, threshold)
    pd.load_model()
    total_model_load_time = time.time() - start_model_load_time
    queue=Queue()
    try:
        queue_param=np.load(args.queue_param)
        for q in queue_param:
            queue.add_queue(q)
    except:
        print("error loading queue param file")
    try:
        cap=cv2.VideoCapture(video_file)
    except FileNotFoundError:
        print("Cannot locate video file: "+ video_file)
        print("Something else went wrong with the video file: ", e)
    initial_w = int(cap.get(cv2.CAP_PROP_FRAME_WIDTH))
    initial_h = int(cap.get(cv2.CAP_PROP_FRAME_HEIGHT))
    video_len = int(cap.get(cv2.CAP_PROP_FRAME_COUNT))
    fps = int(cap.get(cv2.CAP_PROP_FPS))
    out_video = cv2.VideoWriter(os.path.join(output_path, 'output_video.mp4'), cv2.VideoWriter_fourcc(*'avc1'), fps, (initial_w, initial_h), True)
    counter=0
    start_inference_time=time.time()
    try:
        while cap.isOpened():
            ret, frame=cap.read()
            if not ret:
                break
            counter+=1
            coords, image= pd.predict(frame)
            num_people= queue.check_coords(coords)
            print(f"Total People in frame = {len(coords)}")
            print(f"Number of people in queue = {num_people}")
            out_text=""
            y_pixel=25
            for k, v in num_people.items():
                out_text += f"No. of People in Queue {k} is {v} "
                if v >= int(max_people):
                    out_text += f" Queue full; Please move to next Queue "
                cv2.putText(image, out_text, (15, y_pixel), cv2.FONT_HERSHEY_COMPLEX, 1, (0, 255, 0), 2)
                out_text=""
                y_pixel+=40
            out_video.write(image)
        total_time=time.time()-start_inference_time
        total_inference_time=round(total_time, 1)
        fps=counter/total_inference_time
        with open(os.path.join(output_path, 'stats.txt'), 'w') as f:
            f.write(str(total_inference_time)+'\n')
            f.write(str(fps)+'\n')
            f.write(str(total_model_load_time)+'\n')
        cap.release()
        cv2.destroyAllWindows()
        print("Could not run Inference: ", e)
if __name__=='__main__':
    parser=argparse.ArgumentParser()
    parser.add_argument('--model', required=True)
    parser.add_argument('--device', default='CPU')
    parser.add_argument('--video', default=None)
    parser.add_argument('--queue_param', default=None)
    parser.add_argument('--output_path', default='/results')
    parser.add_argument('--max_people', default=2)
    parser.add_argument('--threshold', default=0.60)
    args=parser.parse_args()
    main(args)
Lets gooooooooo!
Could not run Inference:  invalid index to scalar variable.
results/
results/manufacturing/
results/manufacturing/cpu/
results/manufacturing/cpu/output_video.mp4
stderr.log
What could be the problem with my code? Thank You
Eltablawy__Alaa
Hi Keith,
Thanks for reaching out. From the output snippet you have attached, it's not clear what is the problem. Can you please provide more information about the error. You can check the stderr file for the job to find the error log.
Regards.
Alaa
Vids2uda
Hello Keith,
        self.device=device
        try:
In this part of your code, you have already initialized instance of the Inference Engine core while using read_network so you don't need to write again
this line of code while loading model using Load_model function.
