Raspberry Pi 4, 64bit, Arm8 and OpenVino
Isaac_s__Paul
I'm REALLY hoping that now the RPi4 with Arm8 is shipping that OpenVino and the Neural Compute Stick 2 software/libraries are updated to run 64bit on a real 64bit OS rather than the current Arm7/32bit.
I know it's not an 'Intel' CPU but the sheer quantity of devices out there says the number of NCS2 unit sales would jump significantly!
So, Intel, what's the timeline for supporting Arm8/64bit?
Dmitry_K_Intel3
1) OpenVINO is open source library. You can build it for every platform: https://github.com/opencv/dldt
2) Raspberry Pi 3 already had ARMv8 CPU. Raspbian OS is a 32-bit OS that is why CPU is detected as ARMv7
3) New version, Raspbian 10 (Buster) has no huge difference with previous one (Raspbian 9, Stretch). You can try to build existing Raspbian 9 binaries. Source: https://www.raspberrypi.org/blog/buster-the-new-version-of-raspbian/
Isaac_s__Paul
There are some Python 3.5 .so compiled library files in the OpenVINO package.
The OpenVINO setupvars script specifically checks for Raspbian version '9' otherwise the script points to x86 library locations rather than arm7l. Changing the '9' to '10' does repoint but...
Trying to compile Python 3.5.7 from source highlights that libssl has been upgraded from Raspbian 9 to Raspbian 10 and so the compile fails with ssl test certificates being too short (1024 bits rather than the new requirement of >2048 bits). Using ssl files from Python 3.7.4 in place of ssl files in Python 3.5.7 is no good because the code has been developed with some functions that were only introduced in Python 3.6!
So, please please can we have the source files for the 3.5 .so compiled library - or release a new version of OpenVino that will work on the Raspberry Pi 4.
Also, the Raspberry Pi platform is only being used as an inference model loader into the NCS2, i.e. no OpenVino training of models can be carried out on this platform. Yet, by comparison, the Google Coral TPU with Raspberry Pi combo Does allow training to take place.
If you say 'Open' in your package 'OpenVino' then please be 'Open'!
Michael_H_14
I have openvino currently working on the new PI4. I had to recompile everything from scratch. Here is how you do it:
1. Download & install the latest raspbian image: https://www.raspberrypi.org/downloads/raspbian/
2. Clone & build openvino (dldt) and follow instructions at: https://github.com/opencv/dldt/tree/2019/inference-engine#native-compilation
3. Call cmake with these flags:
cmake -DCMAKE_BUILD_TYPE=Release \
-DENABLE_SSE42=OFF \
-DTHREADING=SEQ \
-DENABLE_GNA=OFF \
-DENABLE_OPENCV=OFF \
-DENABLE_PYTHON=ON \
-DPYTHON_EXECUTABLE=/usr/bin/python3.7 \
-DPYTHON_LIBRARY=/usr/lib/arm-linux-gnueabihf/libpython3.7m.so \
-DPYTHON_INCLUDE_DIR=/usr/include/python3.7 \
.. && make -j4
4. Then refer to this link to build opencv 4.1: https://www.pyimagesearch.com/2018/09/26/install-opencv-4-on-your-raspberry-pi/
cmake -D CMAKE_BUILD_TYPE=RELEASE \
    -D CMAKE_INSTALL_PREFIX=/usr/local \
    -D OPENCV_EXTRA_MODULES_PATH=~/opencv_contrib/modules \
    -D ENABLE_NEON=ON \
    -D ENABLE_VFPV3=ON \
    -D BUILD_TESTS=OFF \
    -D OPENCV_ENABLE_NONFREE=ON \
    -D INSTALL_PYTHON_EXAMPLES=OFF \
    -D WITH_INF_ENGINE=ON \
    -D INF_ENGINE_LIB_DIRS="/home/pi/dldt/inference-engine/bin/armv7l/Release/lib" \
    -D INF_ENGINE_INCLUDE_DIRS="/home/pi/dldt/inference-engine/include" \
    -D CMAKE_FIND_ROOT_PATH="/home/pi/dldt/inference-engine/" \
    -D BUILD_EXAMPLES=OFF ..
5. Test your installation with this example: https://www.pyimagesearch.com/2019/04/08/openvino-opencv-and-movidius-ncs-on-the-raspberry-pi/
6. Note that you won't have the setupvars.sh script. Instead just add this to your .bashrc or .profile:
# libraries
export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/usr/local/lib:/home/pi/dldt/inference-engine/bin/armv7l/Release/lib"
NicolaReina
Hi do you see significative improvements wotrh the compile on PI4?
GM__Durga_Prasanna
I bought Raspberry 4 and NCS 2. I want to install and run openvino object detection samples using usb camera. It will be very helpful if you could pointing me to right direction.
Thanks & Regards,
Prasanna
cheiser
Any updates on this?  I tried following the suggestions from earlier in the thread but this doesn't work with RPi4 and the recent 64-bit Raspian release.  I would really like to benchmark the NCS2 performance with the full 64-bit platform.  Thanks, -ch
