- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hello Everyone,
I bought both intel ncs1 and ncs2 for my image classificator app. I used both the sticks on windows 10 with openvino toolkit with latest version. It works fine. Also when I use ncs1 on my Ubuntu 16.04 it works fine as well. But when I unplug ncs1 and plug my ncs2 in Ubuntu, it doesn't work. When I try to infer, I get the following error.
E: [ncAPI] [ 646005] ncDeviceOpen:799 Failed connection to device (1.1-ma2480) with error 5
Segmentation fault (core dumped)
Could anyone please help?
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Dear Sangathamilan, so did you run inference on either the NCS1 or NCS2 ? Or did you merely plug them in and then out ?
Please post your reply here. And thanks for using OpenVino !
Shubha
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Shuba,
Thanks for the reply. I created the IR with model optimizer and tried to run inference with the classification python sample. I ran it with NCS1 first. It works as expected. Then i plug out NCS1 and plug in NCS2 and run the sample again. But I get the error mentioned in the question.
Best,
Sangathamilan
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Dear Raichandran, Sangathamilan:
No doubt this is odd. If I can reproduce it ( I will try and reproduce it today on Ubuntu 16.04 ) I will file a bug.
Thanks for using OpenVino !
Shubha
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thank you. I would wait for further updates then.
Best,
Sangathamilan Ravichandran
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Have you tried to run the sample with NCS2 only? In example, just after reboot of Ubuntu?
Could you paste a content of /etc/udev/rules.d/97-myriad-usbboot.rules ?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Kurtaev,
Thanks for the reply. Yes I have tried running it only on NCS2 after reboot. Please find the content of etc/udev/rules.d/97-myriad-usbboot.rules
SUBSYSTEM=="usb", ATTRS{idProduct}=="2150", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
SUBSYSTEM=="usb", ATTRS{idProduct}=="f63b", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
SUBSYSTEM=="tty", ATTRS{idProduct}=="2150", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
Sanga
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
This way it works or not?
The content looks incorrect. There is no 2485 product ID which corresponds to MyriadX. Which version of OpenVINO is used?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Kurtaev,
No it doesnn't work still. And I am using openvino version 2019.1.094
Best,
Sanga
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Shubha R. (Intel) wrote:Dear Raichandran, Sangathamilan:
Shubha
I can confirm this bug. Platform is Ubuntu 16.04, latest OpenVINO 2019. My code works fine on OpenCL16 but on NCS2 it gives exactly the same error as here
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Could anyone kindly update me on this issue?
Sanga
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Please show us the content of your's /etc/udev/rules.d/97-myriad-usbboot.rules one more time.
Also check an output from lsusb. Is there a device with 03e7:2485 ids?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Kurtaev,
Please find the content from the rules once again below.
And yes there is a device with id 03e7:2485 in the lsusb command (given below are the list of devices)
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 5986:112d Acer, Inc
Bus 001 Device 003: ID 046d:c05b Logitech, Inc. M-U0004 810-001317 [B110 Optical USB Mouse]
Bus 001 Device 006: ID 8087:0a2b Intel Corp.
Bus 001 Device 005: ID 1c7a:0603 LighTuning Technology Inc.
Bus 001 Device 002: ID 03e7:2485
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Best,
Sanga
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
As I already mentioned above, this is incorrect content. Should be the following one:
SUBSYSTEM=="usb", ATTRS{idProduct}=="2485", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
(with 2485 idProduct in the last line)
Please modify it manually or by script. See https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html#additional-NCS-steps.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Kurtaev,
Thanks a lot for the help. Both the sticks are working perfectly alright now. Changing the rules file as suggested helped to fix.
Sanga
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I've got exactly the same problem:
I'm trying to run openvino example with NCS2 on Ubuntu 16.04 and I have an error:
E: [ncAPI] [ 576964] ncDeviceOpen:799 Failed connection to device (1.2-ma2480) with error 5
I have the newest version of openvino 2019.1.133, device ID 03e7:2485 is visible in lsusb.
My 97-myriad-usbbooot.rules file is following:
Could you please help me solve this problem?
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
