6595 Discussions
Error while converting MaskRCnn Tensorflow 2.0 model
Vishnuj
According to the steps mentioned here: https://docs.openvino.ai/latest/openvino_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_Object_Detection_API_Models.html
I tried to convert the MaskRCnn model available at:  https://github.com/tensorflow/models/blob/master/research/object_detection/g3doc/tf2_detection_zoo.md
command:
mo --saved_model_dir /root/sharedfolder/models/mask_rcnn_inception_resnet_v2_1024x1024_coco17_gpu-8/saved_model --transformations_config /root/sharedfolder/models/mask_rcnn_inception_resnet_v2_1024x1024_coco17_gpu-8/mask_rcnn_support_api_v2.4.json --tensorflow_object_detection_api_pipeline_config /root/sharedfolder/models/mask_rcnn_inception_resnet_v2_1024x1024_coco17_gpu-8/pipeline.config" --reverse_input_channels
The conversion is giving me this error:
[ ERROR ]  -------------------------------------------------
[ ERROR ]  ----------------- INTERNAL ERROR ----------------
[ ERROR ]  Unexpected exception happened.
[ ERROR ]  Please contact Model Optimizer developers and forward the following information:
[ ERROR ]  Exception occurred during running replacer "ObjectDetectionAPIPreprocessor2Replacement (<class 'openvino.tools.mo.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPreprocessor2Replacement'>)":
[ ERROR ]  Traceback (most recent call last):
  File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/utils/class_registration.py", line 276, in apply_transform
    replacer.find_and_replace_pattern(graph)
  File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/front/tf/replacement.py", line 36, in find_and_replace_pattern
    self.transform_graph(graph, desc._replacement_desc['custom_attributes'])
  File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/front/tf/ObjectDetectionAPI.py", line 837, in transform_graph
    assert len(start_nodes) >= 1
AssertionError
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/main.py", line 533, in main
    ret_code = driver(argv)
  File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/main.py", line 489, in driver
    graph, ngraph_function = prepare_ir(argv)
  File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/main.py", line 407, in prepare_ir
    graph = unified_pipeline(argv)
  File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/pipeline/unified.py", line 17, in unified_pipeline
    class_registration.ClassType.BACK_REPLACER
  File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/utils/class_registration.py", line 328, in apply_replacements
    apply_replacements_list(graph, replacers_order)
  File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/utils/class_registration.py", line 318, in apply_replacements_list
    num_transforms=len(replacers_order))
  File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/utils/logger.py", line 112, in wrapper
    function(*args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/utils/class_registration.py", line 306, in apply_transform
    )) from err
Exception: Exception occurred during running replacer "ObjectDetectionAPIPreprocessor2Replacement (<class 'openvino.tools.mo.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPreprocessor2Replacement'>)":
[ ERROR ]  ---------------- END OF BUG REPORT --------------
Please help me resolve this issue and help me to convert the Tensorflow model.
Vishnu
Megat_Intel
Hi Vishnu,
The error occurs due to using a different transformations config file.
The Mask R-CNN Inception ResNet V2 1024x1024 model was trained using TensorFlow 2.2, as stated in TensorFlow 2 Detection Model Zoo.
Thus, the correct transformations config file for the model is mask_rcnn_support_api_v2.0.json, which is to be used for Mask R-CNN topologies trained using the TensorFlow* Object Detection API version 2.0 up to 2.3.X inclusively, as mentioned in Convert TensorFlow Object Detection API Models
For your information, I have converted the same model using the command below:
mo --saved_model_dir /mask_rcnn_inception_resnet_v2_1024x1024_coco17_gpu-8/saved_model --transformations_config <openvino_dir>/tools/mo/front/tf/mask_rcnn_support_api_v2.0.json --tensorflow_object_detection_api_pipeline_config /mask_rcnn_inception_resnet_v2_1024x1024_coco17_gpu-8/pipeline.config --reverse_input_channels
Here are my results.
Megat
Megat_Intel
Hi Vishnu,
Megat
Vishnuj
Hi Megat,
Thanks for your reply. I am able to convert the model successfully. Please let me know is there any code/documentation which I can refer, to run inference on the converted MaskRCNN model.
Vishnu
Megat_Intel
Hi Vishnu,
You can find the step-by-step instructions to implement a typical inference pipeline with the OpenVINO™ Runtime C++ API here.
For your information, this thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Megat
