6594 Discussions
Getting error using OpenVINO's Face Recognition Demo
goelradhika
I am trying to run the face_recognition demo application using the cmd:
python .\face_recognition_demo.py -i "<path\to\gallary>\face_gallary\testing\testing13.jpg" -m_fd ..\..\..\..\deployment_tools\intel\face-detection-retail-0004\FP32\face-detection-retail-0004.xml -m_lm ..\..\..\..\deployment_tools\intel\landmarks-regression-retail-0009\FP32\landmarks-regression-retail-0009.xml -m_reid ..\..\..\..\deployment_tools\intel\face-reidentification-retail-0095\FP32\face-reidentification-retail-0095.xml --verbose -fg "<path\to\gallary>\face_gallary\training" --loop
I am getting below error for 2-3 days.
<path>\Python39\lib\site-packages\ngraph\utils\types.py:25: DeprecationWarning: `np.bool` is a deprecated alias for the builtin `bool`. To silence this warning, use `bool` by itself. Doing this will not modify any behavior and is safe. If you specifically wanted the numpy scalar type, use `np.bool_` here.
Deprecated in NumPy 1.20; for more details and guidance: https://numpy.org/devdocs/release/1.20.0-notes.html#deprecations
(NgraphType.boolean, np.bool),
Previously I was able to run the demo, I do not make any changes to the code. I suddenly started getting this error from 2-3 days. Are there any dependency changes that have happened in recent days?
Please provide help and suggestions.
FYI: I am using windows 10. I do not have an additional GPU.
Megat_Intel
Hi goelradhika,
I have successfully run the Face Recognition Python Demo using the same model and parameters as you did. After investigating, I found that the error you obtain occurs due to incorrectly specifying path to the input file, as shown below.
Here are my results when I successfully ran the Face Recognition Python Demo with the correct path to the input file.
On the other hand, the error "DeprecationWarning: `np.bool`" is just a warning. The warning occurs because np.bool in the NumPy package was deprecated. You can refer to Deprecations and DeprecationWarning: `np.bool` for more information on this warning.
Megat
goelradhika
Thanks @Megat_Intel . I observed later, that one underscore was missing in the path, I changed the name of the directory, hence it started giving this error.
Megat_Intel
Hi goelradhika,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Megat
