6573 Discussions
Not able to use customised model to create project and do INT8 calibration
Piyush_Khandelwal
Hi Community,
My aim is to convert a custom model to INT8 IR v11 model using workbench but I'm unable to do so.
I am able to import the onnx model and since I want normalization I have defined Inputs section as well with means and scales. After doing these steps there is not option to go forward and create/evaluate the project and further to do INT8 calibration.
On the other hand if I don't specify Inputs section and avoid normalization then I'm able to use that model and create a project for INT8 calibration.
Attaching the screenshots for the same as well.
Hairul_Intel
Hi Piyush_Khandelwal,
I've validated from my end using squeezenet1.1 and mobilenetv2 from ONNX Model Zoo (This is an external link and is not maintained by Intel) and was able to perform INT8 calibration.
Here are the results of my findings:
Squeezenet1.1 ONNX model:
Mobilenetv2 ONNX model:
Additionally, please share your custom model with us and also provide more details regarding your model, the topology, source repository, etc., for further investigation.
Hairul
Hairul_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Hairul
