Error while installing OpenVINO using pip
Rokaia
I am trying to install openvino using the pip command
pip install openvino-python
but I get this
Collecting openvino-python
  Using cached openvino_python-0.0.0-py3-none-win_amd64.whl (1.4 kB)
ERROR: Could not find a version that satisfies the requirement tbb==2020.2.* (from openvino-python) (from versions: 2019.0, 2020.3.254)
ERROR: No matching distribution found for tbb==2020.2.* (from openvino-python)
Iffa_Intel
Greetings,
If you are trying to get Openvino into your environment, you need to follow the instruction here instead: https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_windows.html
You need to install all of the pre-requisite separately, one by one. Including the toolkit. Once you have it all ready, you can find the Openvino folder placed in your environment automatically.
Note: please ensure you are selecting the correct documentation for your OS.
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question
Sincerely,
Iffa
