Squeezenet 1.0 model is not working when GPU is selected as a device in the openvino version 2020 R4. We tried with our custom app and also the sample app provided by openvino kit. In the both the apps, the app hangs when this model is selected.
-Aankesh
Greetings,
I suggest that you use the latest version of Openvino. The result which runs on GPU as per attached photo is done using the latest Openvino version which is 2021.1 and produced almost immediately.
You can refer here for more information (Please ensure that you select the correct OS accordingly): https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_windows.html
Plus, please help to set up the aditional installation for GPU properly: https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_windows.html#Install-GPU
Sincerely,
Iffa
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question
Sincerely,
Iffa
