6575 Discussions
Error while installing openvino using apt repository
sahinoor
Hope you are doing well.
I was trying to install intel openvino toolkit for linux using apt respository. but when i run the following command :
sudo apt install intel-openvino-runtime-ubuntu20-2021.4.689
i receive the below error :
Depends: intel-openvino-gstreamer-rt-ubuntu-focal-2021.4.689 (= 2021.4-689) but it is not going to be installed
Depends: intel-openvino-gva-rt-ubuntu-focal-2021.4.689 (= 2021.4-689) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
can someone help me with this?
Please find attached the screenshot.
Peh_Intel
Hi sahinoor,
For your information, I’ve validated that the package intel-openvino-runtime-ubuntu20-2021.4.689 is working fine while the package intel-openvino-runtime-ubuntu20-2021.4.582 is broken.
You’re getting Unmet dependencies issues because you installed the broken package intel-openvino-runtime-ubuntu20-2021.4.582 previously.
Uninstall the previous package intel-openvino-runtime-ubuntu20-2021.4.582 and install the package intel-openvino-runtime-ubuntu20-2021.4.689 again:
  1. sudo apt autoremove intel-openvino-runtime-ubuntu20-2021.4.582
  2. sudo apt install intel-openvino-runtime-ubuntu20-2021.4.689
Peh
Peh_Intel
Hi sahinoor,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Peh
