Error while running Interpolate on CPU
Wang__Jie1
VINO Version: 2020.1.023
Tensorflow Version: 1.10.0
System: Ubuntu 18.04
Python: 3.6.5
First I use vino version  2019.3.376,  Model Optimizer faild to  generated IR. Then I download the latest version 2020.1.023,  Model Optimizer successfully generated IR, but my IE fails with the follow info:
terminate called after throwing an instance of 'InferenceEngine::details::InferenceEngineException'
  what():  Interpolate operation should be converted to Interp
Whan should I do to get rid of this error?
Sahira_Intel
Hi Jie,
A few questions for you:
  1. Is this a Caffe or Tensorflow model?
  2. Is this a custom trained model or a pretrained model? Can you please provide your model so I can look at it?
  3. Can you please provide the command you used to convert your model?
Sahira
Wang__Jie1
Thanks for your reply.
1. It's a tensorflow model;
2. It's a custom trained model, I put the model in the attachment;
3. the command is:
python /opt/intel/openvino/deployment_tools/model_optimizer/mo_tf.py --input_model xx.pb --input input_0 --output output_0 --disable_nhwc_to_nchw  --input_shape [1,1024,1024,3]
Jie
johnny765123
I started getting this error when I did a new build of code and model that previously worked. I realised it was only with a debug build that I get this error.  Model is the default YOLOv3 in Darknet, converted via TensorFlow using the instructions in the documentation.  It was converted using the Model Optimizer in OpenVINO 2020.2.117, and run using that same release on macOS.  The only difference between a working build and one that gives the error above is that the working one links to:
@rpath/libinference_engine_legacy.dylib (compatibility version 0.0.0, current version 0.0.0)
@rpath/libinference_engine.dylib (compatibility version 0.0.0, current version 0.0.0)
@rpath/libinference_engine_c_api.dylib (compatibility version 0.0.0, current version 0.0.0)
@rpath/libinference_engine_nn_builder.dylib (compatibility version 0.0.0, current version 0.0.0)
...and the failing one links to (notice the "d" after each library name)
@rpath/libinference_engine_legacyd.dylib (compatibility version 0.0.0, current version 0.0.0)
@rpath/libinference_engined.dylib (compatibility version 0.0.0, current version 0.0.0)
@rpath/libinference_engine_c_apid.dylib (compatibility version 0.0.0, current version 0.0.0)
@rpath/libinference_engine_nn_builderd.dylib (compatibility version 0.0.0, current version 0.0.0)
