6605 Discussions
Error with Intel® Neural Compute Stick, USB port stops work
Dears,
We are developing a solution of analytic video with Intel® Neural Compute Stick on an upboard 2 box with ubuntu 16.04 LTS, but eventually we have a USB port blocked with this error:
cv2.error: OpenCV(4.0.1-openvino) /home/jenkins/workspace/OpenCV/OpenVINO/build/opencv/modules/dnn/src/op_inf_engine.cpp:553: error: (-215:Assertion failed) Failed to initialize Inference Engine backend: Can not init USB device: NC_DEVICE_NOT_FOUND in function 'initPlugin'`
After that, movidius is unavailable and we need to do a physical reboot.
We try to restart usb port, but unsuccessfully. Somebody had same problem?
Thank you in advanced.
Alonso.
Hi @abgenis
Do you see this error when you run other examples as well? Are you using a USB powered hub or plugging directly in?
You might need to reset the NCS device within OpenVINO. There is a parameter KEY_VPU_FORCE_RESET that resets any stalled devices on plugin initialization, it must be used with SetConfig method. Here are some links to help guide in the right direction:
Myriad Plugin, Supported Configuration Parameters
https://docs.openvinotoolkit.org/2018_R5/_docs_IE_DG_supported_plugins_MYRIAD.html
VPU Plugins, VPU Common Configuration Parameters
https://docs.openvinotoolkit.org/2018_R5/_docs_IE_DG_supported_plugins_VPU.html
Please let me know if this is helpful.
Sahira
Hi @Sahira_at_Intel
I'm working together with @abgenis.
About your questions, it follows:
Yes, if an example runs in a stressful manner for a certain period, this problem occurs.
No, we connected the NCS directly to the USB 3.0 port of an UpBoard 2
On redefining the device with KEY_VPU_FORCE_RESET we did this via python, follow code snippet in python3.5
from openvino.inference_engine import IENetwork, IEPlugin
plugin = IEPlugin (device = "MIRYAD")
plugin.set_config ({"VPU_FORCE_RESET": "NO"})
NOTE: In python the KEY_VPU_FORCE_RESET parametyro does not exist, then we use VPU_FORCE_RESET
We do this at the beginning of the code, but we do not succeed. The rest of the instructions are made through opencv 4.0-1-openvino. Follow the passage
import cv2
netMovidius = cv2.dnn.readNet ('my_model.bin', 'my_model.xml')
netMovidius.setPreferableTarget (cv2.dnn.DNN_TARGET_MYRIAD)
frame = cv2.imread ('test_images / image1.jpg'
blob = cv2.dnn.blobFromImage (frame, size = (300, 300))
netMovidius.setInput (blob)
out = netMovidius.forward ()
After starting the inference in the image, we get the error that @abgenis reported above
Hi @RodolfoPlanetfone, @abgenis
Which version of OpenVINO are you using? I'd like to try to reproduce this issue, can you tell me which example you were running and for how long when you ran into the error.
Sincerely,
Sahira
Hi @Sahira_at_Intel
We are using openVINO version computer_vision_sdk_2018.5.455.
Our example is based on converting a pre-trained model to use in openVino in multiple threads for detection in several cameras. We control the frames that we send through a queue, so there is no overhead in the movidius.
Our script usually lasts 7 to 14 days, after that time, we can no longer connect to the movidius inside the operating system, this requires that we turn off the system or change the USB port movidius.
Please upgrade to the latest version of OpenVINO 2019 r1.1 here and try again.
Sahira
Hi, @Sahira_at_Intel,
Thanks for the answer! We will run tests with this version and return with a feedback.
