Exception mkldnn
stone__jesse
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\inference_engine\samples\classification_sample_async\main.cpp
after run this
ExecutableNetwork executable_network = ie.LoadNetwork(network, FLAGS_d); //(FLAGS_d = "CPU")
Exception thrown at 0x000007FEFD42BE0D in classification_sample_async.exe: Microsoft C++ exception: mkldnn::error at memory location 0x000000000264E890.
Exception thrown at 0x000007FEFD42BE0D in classification_sample_async.exe: Microsoft C++ exception: mkldnn::error at memory location 0x000000000264E740.
Exception thrown at 0x000007FEFD42BE0D in classification_sample_async.exe: Microsoft C++ exception: mkldnn::error at memory location 0x000000000264EAD0.
'classification_sample_async.exe' (Win32): Loaded 'C:\Users\Administrator\Documents\Intel\OpenVINO\inference_engine_samples_build\intel64\RelWithDebInfo\tbbmalloc.dll'. Cannot find or open the PDB file.
The thread 0x228c has exited with code 0 (0x0).
The thread 0x488 has exited with code 0 (0x0).
The thread 0x76c has exited with code 0 (0x0).
The thread 0x23dc has exited with code 0 (0x0).
The thread 0x1cc8 has exited with code 0 (0x0).
The thread 0x5d4 has exited with code 0 (0x0).
The thread 0x1678 has exited with code 0 (0x0).
The thread 0x23b4 has exited with code 0 (0x0).
The thread 0x1cf0 has exited with code 0 (0x0).
'classification_sample_async.exe' (Win32): Unloaded 'C:\Users\Administrator\Documents\Intel\OpenVINO\inference_engine_samples_build\intel64\RelWithDebInfo\MKLDNNPlugin.dll'
'classification_sample_async.exe' (Win32): Unloaded 'C:\Users\Administrator\Documents\Intel\OpenVINO\inference_engine_samples_build\intel64\RelWithDebInfo\mkl_tiny_tbb.dll'
The program '[8552] classification_sample_async.exe' has exited with code 0 (0x0).
Shubha_R_Intel
Dear stone, jesse,
This is strange. Does this occur when you run  classification_sample_async.exe ? Please delete your old build directory (from a previous OpenVino installation). Then run setupvars.bat and re-build. In Openvino 2019R2 there are now two folders, samples and demos so you must run build_demos_msvc.bat under C:\Program Files (x86)\IntelSWTools\openvino_2019.2.242\inference_engine\demos and also build_samples_msvc.bat under C:\Program Files (x86)\IntelSWTools\openvino_2019.2.242\inference_engine\samples .
The error looks to me as if you're mixing setupvars.bat and samples built from 2 different OpenVino versions. OR, you've built a debug version and you're running setupvars.bat which looks for a Release version by default. You always need to modify setupvars.bat to reflect the correct build configuration - Debug or Release.
Shubha
