Exception: mvncStatus.ERROR
I've tried 'make examples' but failed with mvncStatus.ERROR.
Here is my error message after make run.
making compile mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt mvNCCompile v02.00, Copyright @ Movidius Ltd 2016 Layer inception_3b/1x1 forced to im2col_v2, because its output is used in concat Layer inception_3b/pool_proj forced to im2col_v3, because its output is used in concat Layer inception_4a/1x1 forced to im2col_v2, because its output is used in concat Layer inception_4a/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_4b/1x1 forced to im2col_v2, because its output is used in concat Layer inception_4b/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_4c/1x1 forced to im2col_v2, because its output is used in concat Layer inception_4c/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_4d/1x1 forced to im2col_v2, because its output is used in concat Layer inception_4d/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_4e/1x1 forced to im2col_v2, because its output is used in concat Layer inception_4e/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_5a/1x1 forced to im2col_v2, because its output is used in concat Layer inception_5a/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_5b/1x1 forced to im2col_v2, because its output is used in concat Layer inception_5b/pool_proj forced to im2col_v2, because its output is used in concat /usr/local/bin/ncsdk/Controllers/FileIO.py:52: UserWarning: You are using a large type. Consider reducing your data sizes for best performance "Consider reducing your data sizes for best performance\033[0m") making run ./run.py Device 0 Address: 3 - VID/PID 03e7:2150 Starting wait for connect with 2000ms timeout Found Address: 3 - VID/PID 03e7:2150 Found EP 0x81 : max packet size is 512 bytes Found EP 0x01 : max packet size is 512 bytes Found and opened device Performing bulk write of 865724 bytes... Successfully sent 865724 bytes of data in 1054.742965 ms (0.782768 MB/s) Boot successful, device address 3 Device 0 Address: 2 - VID/PID 03e7:f63b Found Address: 2 - VID/PID 03e7:f63b done Booted 2 -> VSC Traceback (most recent call last): File "./run.py", line 66, in <module> graph = device.AllocateGraph(blob) File "/usr/local/lib/python3.5/dist-packages/mvnc/mvncapi.py", line 203, in AllocateGraph raise Exception(Status(status)) Exception: mvncStatus.ERROR Makefile:91: recipe for target 'run' failed make: *** [run] Error 1
I think the device is connected successfully because I can compile ncsdk/examples/apps/hello_ncs_py.
Here are the logs I got.
ncsdk/eamples/apps/hello_ncs_py$ make run making run python3 hello_ncs.py; Hello NCS! Device opened normally. Goodbye NCS! Device closed normally. NCS device working.
I did re-clone NCSDK and reinstall, but still failed.
What should be my next debugging step?
Is there any driver I should install?
The followings are my environments details.
  • MV0212 EVM board with Myriad2 MA2450 (USB Device Boot mode 0x2)
  • Host Windows 7 64bits
  • Virtualbox Ubuntu 16.04 64bits
  • Two USB filters : Movidius NSC LoopbackDevice [0100] / Movidius Ltd. Movidius MA2X5X [0001]
Heera
@hra.kim You may have to double check your USB filters. In your log below, I noticed that initially the device address number is 3 Device 0 Address 3 but the device address number changes after the Boot successful, device address 3 line. The Device address number should stay the same. @GoldenWings has some nice screenshots and tips @ https://ncsforum.movidius.com/discussion/comment/1052/#Comment_1052.
Snippet from your log:
Thank you, this problem has been resolved
I am facing this same issue even after following the instructions by @Tome_at_Intel . Is there a fix for this?
Hi @Kaushik
Thank you for reaching out, I suggest you to start a new thread with the fill error message you are seeing.
If you can also provide additional details about your setup (Virtual Machine?, OS, SDK version, output of lsusb, etc).
Jesus
