OpenVino install on Raspian RPi
Koller__Daniel
in "Build and run object detection sample" step 3 I am stuck with the following output on Raspian:
pi@raspberrypi:~/openvino/inference_engine_vpu_arm/deployment_tools/inference_engine/samples/build $ cmake .. -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_FLAGS="-march=armv7-a"
CMake Error at CMakeLists.txt:60 (find_package):
  By not providing "FindInferenceEngine.cmake" in CMAKE_MODULE_PATH this
  project has asked CMake to find a package configuration file provided by
  "InferenceEngine", but CMake did not find one.
  Could not find a package configuration file provided by "InferenceEngine"
  (requested version 1.5) with any of the following names:
    InferenceEngineConfig.cmake
    inferenceengine-config.cmake
  Add the installation prefix of "InferenceEngine" to CMAKE_PREFIX_PATH or
  set "InferenceEngine_DIR" to a directory containing one of the above files.
  If "InferenceEngine" provides a separate development package or SDK, be
  sure it has been installed.
-- Configuring incomplete, errors occurred!
See also "/home/pi/openvino/inference_engine_vpu_arm/deployment_tools/inference_engine/samples/build/CMakeFiles/CMakeOutput.log".
--° any ideas how to fix that? (adding the location of the cmake files to the mentioned env variable did not help)
Kind regards,
Daniel
