- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi, Im using a custom neural network developed in pytorch with two inputs named frame and prob. I converted the model to onnx format and trying to convert it to openvinoIR format. I get an error during the conversion. Can someone help me here or provide an example where conversion has been done for models with two inputs ?
Please find the configuration settings and the observed error below,
Exporting ONNX model to IR... This may take a few minutes. Model Optimizer arguments: Common parameters: - Path to the Input Model: \openvino_notebooks\notebooks\102-pytorch-onnx-to-openvino\Segmentation_colors .onnx - Path for generated IR: \openvino_notebooks\notebooks\102-pytorch-onnx-to-openvino\. - IR output name: Segmentation_colors - Log level: ERROR - Batch: Not specified, inherited from the model - Input layers: frame, prob - Output layers: Not specified, inherited from the model - Input shapes: [1,512, 896, 3], [1,512, 896, 4] - Mean values: Not specified - Scale values: Not specified - Scale factor: Not specified - Precision of IR: FP16 - Enable fusing: True - Enable grouped convolutions fusing: True - Move mean values to preprocess section: None - Reverse input channels: False ONNX specific parameters: - Inference Engine found in: \openvino_env\lib\site-packages\openvino Inference Engine version: 2021.4.0-3839-cd81789d294-releases/2021/4 Model Optimizer version: 2021.4.0-3839-cd81789d294-releases/2021/4 [ ERROR ] Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.front.user_data_repack.UserDataRepack'>): No node with name frame
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Uthara Keerthan Ramamoorthy,
Here is another workaround you can try, for --input frame, prob try to change it to --input 0,1.
Sincerely,
Zulkifli
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Greetings to you,
Can you share with us your model? We will take a look at it.
Sincerely,
Zulkifli
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Yes, of course.
Which file format do you need ? Can I send the onnx model format ?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Based on the Conversion Parameter documentation, conversion with 2 inputs is possible.
It seems like the input notes were not recognized. I successfully converted your ONNX model to IR format without using any parameters/arguments. Please give it a try and share with us the result.
Sincerely,
Zulkifli
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Sincerely,
Zulkifli
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Would you mind telling us which method did you used? Convert the ONNX model without the arguments or change the input nodes to 0,1?
Sincerely,
Zulkifli
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thank you for confirming your issue has been resolved. This thread will no longer be monitor. If you need any additional information from Intel, please submit a new question.
