Execution time for mask-RCNN too long
Truong__Dien_Hoa
New Contributor II
I can successfully running mask-RCNN with open vino optimizer. However, the execution time is quite long. On CPU, For the mask_rcnn_demo it took 4.5 s for one iteration. I have written a python version of it and the result is similar. I haven't tried it yet with GPU but can someone who have experience on it can tell me the capability of mask-rcnn on openvino ? It is even slower than running with opencv, I remember it is about 2s/iteration on my PC.
I read that it is not supported yet with VPU but is GPU can improve the performance ?
Thank you so much in advance,
Hoa
Ponchon__François
Hey !
From my own experience, i noticed that the first image is everytime slower than others.
For my own project, i process subimages from multiframe tiff images, and i see that the first one is maybe 2 or 3 times longer than others, maybe the time to load the model and network inside ram or cache memory... I don't know !
I recorded my inferences time for image 800x1067 on an intel i5-6200U :
Compute times are like that :
[Info] Classes Definition Succeed...
[Info] Colors Definition Succeed...
Creating Directory... ./Results ... Succeed
 Image 1
elapsed time: 3709ms
 Image 3
elapsed time: 2217ms
 Image 5
elapsed time: 2210ms
 Image 7
elapsed time: 2223ms
 Image 9
elapsed time: 2236ms
 Image 11
elapsed time: 2393ms
 Image 13
elapsed time: 2288ms
 Image 15
elapsed time: 2255ms
Saving File... ./Results\05899706_k_p1.tif
This time include :
  • Resize Subimage
  • Inference
  • draw defects
I have exactly the same things when i use OpenCV DNN Engine :
 Image 1
elapsed time: 4688ms
 Image 3
elapsed time: 4111ms
 Image 5
elapsed time: 4048ms
 Image 7
elapsed time: 3987ms
 Image 9
elapsed time: 4004ms
Image 11
elapsed time: 4446ms
Image 13
elapsed time: 4337ms
Image 15
elapsed time: 4124ms
Truong__Dien_Hoa
New Contributor II
Wow, it's quite weird that it takes me more time than you. Which code (sample) exactly did you use ? I ran it in python with image taking from webcam. For the mask rcnn demo I ran just 1 image.
Thank you,
Hoa
Truong__Dien_Hoa
New Contributor II
Now the inference time reduce in my case to 2s/frame as yours. However, it is still slow. I'm thinking about trying other model like mask rcnn with mobilenet backbone or Deeplab following this page https://github.com/PINTO0309/OpenVINO-DeeplabV3 . I'm very appreciated if someone with experience on this can give me advices.
Thank you in advance
Hoa
Hyodo__Katsuya
Innovator
Same issue. A conversation between me and "dhoa". https://ncsforum.movidius.com/discussion/comment/4548/#Comment_4548
Truong__Dien_Hoa
New Contributor II
@Katsuya,
Hei, "dhoa" it's me there :D, thank you for coming here, I'm kind of nervous character so asking question everywhere.
Actually now I'm testing several models on UP square board with an Intel Pentium N4200.
- Mask RCNN is just too slow. I get 0.1FPS on CPU and 0.2FPS on GPU
- Deeplab as you said is not fully supported by OpenVINO then we need to offloading Tensorflow layer. However, I'm not succeed yet to install tensorflow on UP board. I think I need to install it from source and not just by using pip. Because of this difficulty, I reversed back and checked your UNet model. I found that it has about 5FPS (same as Deeplab) on CPU with my computer so I tried it on the UP board.
- UNet on UP board: CPU : 1.6FPS         GPU: 2.5 FPS
Actually, for me 2.5 FPS is still slow. I stay with UNet now because of its easy to use OpenVINO but very appreciated if someone have new idea on this segmentation problem.
Thank you,
Truong__Dien_Hoa
New Contributor II
Hi @Hyodo Katsuya , Can I ask you how do you get your Unet model ? I can't find unet verified frozen model (like training on Pascal VOC model) which have good performance like the Deeplab model you share.
Thank you in advance,
