6627 Discussions
Expose DLL that depends on Inference Engine to Python using Boost.Python
fabda01
I have created a DLL for Windows that depends on Inference Engine and now I want to develop a python package that uses this DLL.
To create a python package that can access the functions of this DLL I am using [Boost.Python](https://www.boost.org/doc/libs/1_63_0/libs/python/doc/html/tutorial/index.html).
I have used Boost.Python before to develop python packages that depends on OpenCV and never had any issues.
However, when I create a DLL that depends on the Inference Engine I get runtime error. Specifically for MKLDNNPlugin.dll
The error message is
RuntimeError: Failed to create plugin C:\local\Release\MKLDNNPlugin.dll for device CPU
Please, check your environment
Cannot load library 'C:\local\Release\MKLDNNPlugin.dll': 126 from cwd: C:\local\Release
I have seen many issues reported with "Cannot load library MKLDNNPlugin.dll"
Among the solutions are:
- run setupvars.bat
- copy MKLDNNPlugin.dll to the same location as my output DLL
Unfortunately, none of these have worked.
I have tried wrapping in a DLL one of the simplest Inference Engine samples available, namely [hello_classification](https://github.com/openvinotoolkit/openvino/blob/master/inference-engine/samples/hello_classification/main.cpp) and uploaded [a minimal, complete and verified example](https://github.com/ddfabbro/boost_python_inference_engine/tree/master) to Github
### My environment:
- Visual Studio 2019
- OpenVINO 2020.3 (Installed from precompiled binaries)
- OpenCV 4.3 (Comes with OpenVINO 2020.3)
- Boost 1.71
- Python 3.7
IntelSupport
Community Manager
Hi Davi,
Thank you for waiting. This case is possibly due to a linker/environment issue. My advice is please use the 'Deployment Manager' to deploy your application to a target device if that is your ultimate goal. This command-line tool assembles the model, IR files, the application, and associated dependencies into a runtime package for the target device. Please refer to this guide for more information:
https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_deployment_manager_tool.html
Adli
IntelSupport
Community Manager
Hi Davi,
Thank you for reaching out to us. We are currently investigating this issue and we will come back to you soon.
Adli
IntelSupport
Community Manager
Hi Davi,
Adli
IntelSupport
Community Manager
Hi Davi,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Adli
