6627 Discussions
Import Error ModuleNotFoundError: No module named '_pyngraph'
simranS
Hi I am trying to inference inside openvino with Intel python distribution using the following Command, but it throws error:  ModuleNotFoundError: No module named '_pyngraph'
Openvino Version: 2021.1
Intel Python Distribution: Python 3.7.7 :: Intel Corporation
Error:
python object_detection_sample_ssd.py -m /home/ubuntu/Documents/Simran/frozen_inference_graph.xml -i /home/ubuntu/Documents/Simran/images/images_2_134.jpg
/home/ubuntu/Downloads/intelpython3/lib/python3.7/importlib/_bootstrap.py:219: RuntimeWarning: compiletime version 3.6 of module 'openvino.inference_engine.ie_api' does not match runtime version 3.7
return f(*args, **kwds)
/home/ubuntu/Downloads/intelpython3/lib/python3.7/importlib/_bootstrap.py:219: RuntimeWarning: compiletime version 3.6 of module 'openvino.inference_engine.constants' does not match runtime version 3.7
Traceback (most recent call last):
File "object_detection_sample_ssd.py", line 26, in <module>
import ngraph as ng
File "/opt/intel/openvino_2021/python/python3.6/ngraph/__init__.py", line 26, in <module>
from ngraph.impl import Node
File "/opt/intel/openvino_2021/python/python3.6/ngraph/impl/__init__.py", line 35, in <module>
from _pyngraph import Dimension
IntelSupport
Community Manager
Hi Simran,
Thank you for posting in Intel Distribution for Python forum. We're trying it out from our end. We'll get back to you shortly.
Gopika
IntelSupport
Community Manager
Hi Simran
This issue seems to be related to Openvino. We've a separate forum for Openvino toolkit. So we're moving this case to Openvino toolkit forum for faster response.
Gopika
Iffa_Intel
Greetings,
Usually, these kind of error persist when the setupvars is not initiated. Please note that you need to run it each time you open a new terminal/cmd. Better if you could set it up permanently.
Ensure that you are able to run the demo as in this tutorial: https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_linux.html
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
